Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
I will look into it. Funny thing Mazak, I am importing the Xstream scene into C4D anyway, so I can just put those bits in I guess. I will try it in C4D.
But I like the nice glowy premade neon material in vue. I want to make a neon sign.
Love esther
I aim to update it about once a month. Oh, and it's free!
do it in C4D then export to Vue for texturing ? Bit long winded but it should work
My Freebies
Buy stuff on RedBubble
that might be a good idea then i can position it where i want it in respect to the vue scene much easier
love esther
Well - i don't know exactly, how you want your text positioned, the length of it, the angle or whatever, but sure you can use the text function of VUE and run a text in a curve.
Your first guess to use a cylinder, for example, is only one object, that can be used as the base shape of a curve.
Just produce your text - the letters in a word are grouped, but in the object list window to the right you can select each single letter one after each other.
Call up a cylinder object, rotate it 270 degrees - . Now you have the text hovering above the cylinder. The diameter of the cylinder has to be bigger than the length of the text/words.
Now select each single letter one after each other and use VUE's normal or intelligent object drop function - for sure you use this function a lot for other stuff - the lowest button on the left side vertical bar.
Then repeat this for each letter - just watch out, that there is just enough space between each letter, that they can't touch each other while dropping onto the cylinders perimeter.
If you look at the above example image - the green text was done by using the intelligent dropping with the right mouse button - the red text was done by using the normal dropping with the left mouse button. The red text was more work, because after normal dropping each letter is always standing vertical, doesn't matter the curved surface below. There i just selected each letter and just rotated each a bit to fit their angle to the cylinder curve.
Sure this can be done with easier functions in other 3D applications, but if you want to use the VUE text rightaway and don't want to start exporting-importing-exporting-importing stuff, this is a way to do it.
oh very clever. I did make one in C4D but I will certainly try this way too. Thanks so much.
Love esther
eg around a cylinder or something?
Love esther
MY ONLINE COMIC IS NOW LIVE
