Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
You might want to look at Blender - it's a huge modeling suite but it has a lot of nice uvmapping features.
http://wiki.blender.org/index.php/Manual/Unwrapping_a_Mesh
Don't you have Cinema 4D? If you do then you probably want to look at the UVmapping tools included with Bodypaint, very powerful.
Attached Link: http://www.morphography.uk.vu/uvmapping.html
I'm sure RoadKill and UVMapper can do the job between them - I used that combination to map my recent Nancy Boots freebie, and I think the map turned out ok. Was there something particular you're having trouble with? Here's a link to my tutorial, in case you haven't seen it.Quote - You might want to look at Blender - it's a huge modeling suite but it has a lot of nice uvmapping features.
I have tried blender in the past not a program I think I could learn.
Poserverse The New Home
for NYGUY's Freebies
Quote - I'm sure RoadKill and UVMapper can do the job between them - I used that combination to map my recent Nancy Boots freebie, and I think the map turned out ok. Was there something particular you're having trouble with? Here's a link to my tutorial, in case you haven't seen it.
Problem with Roadkill it clears out the grouping of my obj file after I export it. I cannot find any settings to keep the groups in tack. UVMapper I cannot get the maps to relax like I want with Roadkill. I think I am at version UVMapper 2 Pro
Quote - *Problem with Roadkill it clears out the grouping of my obj file after I export it.
Read Bob's Tutorial he linked for you. he shows you how to fix that.
if I had time right now to read it I would be we are starting to get busy here at work.
I cross-posted with Khai. Here's the executive summary:
In UVMapper, open the model you saved from RoadKill. Go to File > Export UVs. Make sure that all the options are unchecked so you get only the UV mapping.
Open up your original (grouped) model in UVMapper.
Now go to File > Import UVS, and select the file you saved in step 1. This applies the RoadKill mapping, but doesn't change the scaling, or overwrite the original grouping or material zones.
Can I just say thanks Bob?
I hate Tuesdays, we are always busy between 9AM and 10AM. Plus it does not help that our systems are slow this morning.
Khai, sorry if I sounded snippy. It is easier for me to glance at a reply in the forum than to read a tutorial while at work.
I happen to be digging the UV map unwrapping in Hexagon :)
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
Quote - I happen to be digging the UV map unwrapping in Hexagon :)
I have not the played with Hexagon's UV tool in awhile and don't currently have it installed. I will give EB's method a shot first.
EB just had a chance to try your method works great thanks
Quote - Cool. When might we see the results?
Soon I hope, I am not the best at textures and hope with the reference images I have to this complete in a few days. I have set a few hours a side on Saturday to for just poser work since I am stuck in front of my system checking work emails for a few hours.
On a side note what is the best size to save templates at?
Quote - On a side note what is the best size to save templates at?
Whatever's a comfortable size for you to work with, which will depend on the size of your screen among other factors. I usually go for 1024 x 1024, although I might go larger for figures. 1024 is quite large for shoe textures, unless they're going to be seen in closeup - but you can always shrink them.
Quality Is what I am looking. I want the best bang for the buck, specially if I decide to sell this product.
Well, if you take an average full-figure render in the gallery here, the shoes aren't going to cover more than a hundred or two pixels square (those that are wearing shoes, that is... :D ) For that use, having a shoe texture bigger than 256 x 256 is a waste of your customer's memory - bang for the buck doesn't really come into it. Of course, if the render is going to end up on a huge poster, or if they're going to do an extreme close-up, then something larger would be necessary.
What's convenient is another matter. I'm not an expert texture artist either, but I prefer to work at a large scale and optionally resize afterwards, if there's going to be a lot of fine detail. It's easier to draw something small (stitching, for example) a few pixels wide, than it is to do it at the final size which may be less than a pixel across.
Here is one of the reference images I am using for textures. Not the shoe laces but going to try a bump map or displacement. If push comes to shove I will figure out the best to model the laces.
Just an update. I SUCK AT TEXTURES!
I am going to have to redo some of the modeling and remap it a little different due to the way is looks when I have simple textures. I tried a bump map for the shoe laces and decided that is not the way to go, so I am just going to have to make some laces that will fit.
I need help mapping a shoe set I am working on. Besides Roadkill and UVMapper are there any other Mapping tools that are free or cheap?
Poserverse The New Home for NYGUY's Freebies
