Sun, Jan 26, 4:44 AM CST
Subject: Poser Pro-Bug in the material room?
CauriBlackthorne ( ) posted Tue, 12 August 2008 at 4:12 PM · edited Fri, 24 January 2025 at 10:57 PM
Is it just me, or is there a bug in the material room? When I try to change the values there´s either an "overreaction" in increase or no change. On the pic you can see Don rendered in Poser Pro ( left) and Poser 7 ( right ). The texture strength is set in both renders to 1,1. Standard poser lightning an basic out of the box render settings. As you can see, the texture in Poser Pro comes out to dark ( eyebrows), I have to use at least a texture strength of 1,3- 1,5 to achieve the same darkness in Poser 7. I spent most of my evening trying to create a decent looking hair shader with no success, the texture came out either to dark or to light, minor dial twisting had huge effects on the darkness or lightness of the textures. It even gets worse when you use blender nodes. I´m not a newbie to the texture room, I used it a lot in P6 and even more often in P7, so I´m pretty sure it´s not my fault.
CauriBlackthorne ( ) posted Tue, 12 August 2008 at 5:01 PM
Found out, that turning off the gamma correction solves my problem....
