Your problem isn't resolution but quality.
First of all set your render resolution the same as your movie resolution (currently your render resolution is 551x367 while your movie resolution is 720x480). Most people render out as separate pictures with the best quality and use another program to turn these into a movie. Most separate programs are capable of providing a better quality (with many different formats and often better compression). All Poser movie compression algorithms are only good enough for a quick preview, they do not provide enough capabilities to properly create good quality movies.
Also keep in mind that with moving pictures quality of single frames is less of an issue. As always it is a compromise between quality and size, the better the quality of the individual frames the bigger the movie file becomes.
Thanks to Miss Nancy
But....
You can download file
http://www.bokgi.net/test/resolution.zip
Help me please...
You used the Codec "Microsoft Video 1" for the AVI. This codec is outdated and will produce poor quality.
You will need another codec, or your video will look bad.
Try xvid as your video codec, should work better:
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
Question about movie resolution.
Hi.
I have a question about movie resolution.
I want to make movie.
Next image is in poser 5.
Final movie is like next
How can I make movie high resolution?
Help me please.
