Sat, Jan 25, 7:25 PM CST
Subject: Exporting Trees
alkart2003 ( ) posted Mon, 18 August 2008 at 11:37 AM · edited Tue, 13 August 2024 at 11:03 PM
When I try to export trees the texture map is alaways screwed up.  How should I go about doing this so everything in my other program  will look the same as it did in Vue.
alkart2003 ( ) posted Tue, 19 August 2008 at 9:59 PM
You mean to tell me that know one out there has run into this same problem!  Can someone direct me to another forum to check besides this one or E-on's forum.  No one seems to be responding to my post.
Peggy_Walters ( ) posted Wed, 20 August 2008 at 8:09 AM
The thing is, the tree won't look the same as is does in Vue.  Most of the trees use procedural textures.  When you export, Vue will convert them to bitmap materials.  It does an OK job, but it will not look as good as it does in Vue...
LVS - Where Learning is Fun!
