Mon, Jan 20, 7:27 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:19 am)
Subject: glowing hair lit
dyo ( ) posted Sun, 07 September 2008 at 11:09 PM · edited Sun, 05 January 2025 at 1:22 AM
 Hi people,
How do I get the hair in poser not to glow as if it is lit by other lights ?
If I have the body lighting right the hair is way to bright , and if the hair is lit right then the body is to dark .
any hints please
Dyo
Dyo Sloneclaw
Struggling unemployed Artist
Poser 6 on VMware Fusion windowsXp immulator on mac osx 10.6.7
Winterclaw ( ) posted Tue, 09 September 2008 at 11:49 PM
Well, I can think of two things.  One is you render them seperately and then shop the hair onto the body in postwork.
The other idea and this is just a guess because I've never used that feature is gather (check the stickies on the top of the forum for links to it).  If you could use a dark enough color or a negitive one, that might work.  Or you could use a lot of tiny, dark point based lights with a very close max distance, but that could be a ton of work depending on the hair you chose.
I'd suggest doing it in post work.  To make it easier, do it against a green or blue background and delete the links to the texture on facial regions and make them the same color as your background.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
dyo ( ) posted Wed, 10 September 2008 at 2:44 AM
thanks winterclaw
I already do them in Photoshop now after doing 2 renders, 1 lighting setup for the body and  the second for the hair
I was hoping that i just had a setting wrong some where , seems if you put lights behind the figure all the hair glows , the light doesn't know there is a head blocking it , backlighting is not very good in poser .
Dyo Sloneclaw
