Mon, Jan 27, 8:29 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: can a python script make Poser open a certain folder in the Lib. Palette?
z ( ) posted Thu, 11 September 2008 at 2:54 PM · edited Mon, 27 January 2025 at 8:20 AM
so that the user could see the contents?
semidieu ( ) posted Thu, 11 September 2008 at 3:01 PM
No... This is not possible (or if it is, I'm really really curious :) )
PhilC ( ) posted Thu, 11 September 2008 at 6:04 PM
There may be a route to it by writing to the LibraryPrefs.xml file but it might not take effect until the next time you open Poser. What exactly is it that you are trying to do?
semidieu ( ) posted Fri, 12 September 2008 at 6:55 AM
No... this doesn't work I think, because Poser automatically writes the new LibraryPrefs.xml file on exit (except if you force exit using sys.exit() )
