Wed, Jan 15, 1:48 PM CST
Forum Moderators: Staff
Subject: Error Message
webmagic ( ) posted Mon, 25 June 2001 at 12:18 PM · edited Wed, 15 January 2025 at 11:22 AM
Hello, I have loaded a figure and set it as my default. Now everytime I open Poser I get this error message-No groups in geom,cannot make rsrc file. What is happening? Thank you to anybody who will help me. I have several other PZ3 files using this same figure, and only the props are showing up. I just got a new computer and am trying to rebuild everything the way I had before, what a pain. So I am sure there will be more questions as the kinks get worked out. But I am so happy my computer doesn't die anymore.As you can tell I am new to Poser, but I am slowly learning. Thank you, Webmagic
bloodsong ( ) posted Mon, 25 June 2001 at 6:03 PM
heyas; it sounds as if the figure's geometry rsr file has become corrupted. first, find the obj file that your figure is using. if you dont know, you can find a pointer to it in the cr2. then, go to that directory and delete the rsr file that is the same name as the obj file. re-start poser and see if that helps.
