Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Looking at my Mac Activity Monitor while rendering in the Background or using Queue Manager, it appeared to be using only one thread instead of the 4 it uses rendering manually. Maybe that's why it's slower? Just a thought...
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
Are you using the Queue renderer to render on the same computer that you have your Poser
program on? That's not really what it is intended for. It supposed to be used with
other computers on a network as a render farm so that you can have several computers
doing the renders all at once. So say you have 4 other computers in your network, in addition
to the one that has Poser installed on it. Now try sending the animation frames to
those computers using the queue manager, and then try using your Poser computer
to render the same amount of frames with background render, and see which is faster.
If all you have is the one computer, then basically the queue renderer is useless and
you are better of just using the background renderer.
@ dbowers22: Nearly, but not quite useless. I can set off a render in the queue manager, then close that scene in Poser and open another one to work on. Then send that to the queue manager, close Poser and go to bed leaving them both to render overnight. That's very useful for me.
Izi
what I should be."
Murakami)
Could be that the queue manager gets assigned a background process priority. Have you tried giving higher execution priority to the queue manager?
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
Quote - For single frames, the queue can be slower since it has to first read and parse the pz3 file before it can fire off a render. When you start a render from within Poser, that part has been done already.
This is the same conclusion I came to.
So the question is, how can we get maximum render performance out of poser cough PRO cough without using the queue manager? The queue manager requires an additional computer on the network to soak up the loss of performance from the loading time (very lame).
Any ideas? I was thinking of writing a script of some kind that will render each frame using the background renderer, then export it as an image file all from within poser pro.
Proper methodology.
Queue Manager Methodology (Great if you have a network farm)
Save a pz3 file (makes sense)
Open pz3 file (performance penalty, add an extra computer to make up for this loss of time)
Render frame 1
Export image
Close pz3
Open pz3 file again (performance penalty)
Render frame 2
etc...
So I made a 160 frame animation and now I'm testing render speeds. Me vs the Queue Manager.
Manual Render & Export using the Background Render
**Automatic Render & Export using the queue manager & "image files" options under "make movie", then doing "Send to queue".
*- Each frame takes roughly 40 seconds. *The queue manager is not as fast as doing it manually. Queue Manager takes twice as long!!!!
I can understand the first frame taking a long time since it needs to save it's own PZ3 file. But every frame after that should be as fast as me doing it manually. Then again this is coming from a company that uses network sockets to communicate between threads laugh.
So anyone know how to get the queue manager to perform as good as rendering images manually? I might be doing something wrong. It doesn't make sense for the queue manager to be this slow.
