Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 30 7:03 pm)
Attached Link: "Grouping Tool" compliments of Dr Geep Studios
*(click image to view full size) (click link above image to view complete tutorial)*Hi Red,
Use the Grouping Tool (Group Editor) and use the "Reverse Group Normals" button.
See Page 13 (below)** ** in the attached link to the complete tut.
cheers,
dr geep
Graphic to follow ...
cheers,
dr geep ... :o]
edited 10/5/2019
Well, the graphic didn't follow .......... because ...... I got it (Page13) posted in the previous post.
cheers,
dr geep
Addendum to Page 13 note:
"If the prop ... "
Try this: ............ to do all the groups at the same time.
cheers,
dr geep ... :o]
edited 10/5/2019
Thanks but that flips all the normals and only some of them need it. I know I can select some of the normals and flip them, but there are quite a few and some are really tiny. I guess I'm just being lazy and hoping for a short cut.
If you have a modeler, look for a feature like "align normals" and just fix it in your modeler.
If it's a prop with no morphs or what have you, can also try this and see if it might fix things (if you don't have a modeler):
If embedded in the pp2 file, export it from Poser as OBJ, then on re-import, clear all boxes except the one that says "Make polygon normals consistant" (or something along those lines)
If it's a referenced obj in the pp2 file, find the geometries folder with the OBJ file in it, and then do the same import step as above.
Crazy alien chick FTW! (yeah....right....)
Realm of Savage - Poser
goodies and so much more!
I have some props that the normals are facing the wrong way. I know I can check normals forward in the materials room but that doesn't in preview mode and it is kinda difficult to pose fiures around it when you can hardly see it. Is there something I can do to fix this aside from selecting individual normanls and flipping them?
