Thu, Jan 9, 3:54 AM CST
Subject: What does this do?
Inspired_Art ( ) posted Tue, 23 September 2008 at 11:45 AM · edited Wed, 08 January 2025 at 1:24 PM
Been messing around with the dials on Victoria 4.2, but so far this one (in red) doesn't do anything
Eddy
IsaoShi ( ) posted Tue, 23 September 2008 at 1:05 PM · edited Tue, 23 September 2008 at 1:05 PM
It reduces the strength of the Joint Controlled Magnets effect. Zero gives full strength, minus 1 gives zero strength.
What's that? You don't know what JCMs are? Basically, they are built-in magnets that operate when you move a joint away from its zero position. For example, lift an arm, and V4's breast lifts up and stretches. It's a JCM doing that.
Inspired_Art ( ) posted Tue, 23 September 2008 at 1:38 PM
Thanks! That cleared something else up! 👍
Eddy
bopperthijs ( ) posted Tue, 23 September 2008 at 3:03 PM · edited Tue, 23 September 2008 at 3:04 PM
*What's that? You don't know what JCMs are? Basically, they are built-in magnets that operate when you move a joint away from its zero position. For example, lift an arm, and V4's breast lifts up and stretches. It's a JCM doing that.
*I'm sorry to say but that's not completely correct. JCM is short for joined controlled morph.
JCM's are used for a long time, Victoria 3 and other models had it already. Joint controlled magnets or deformers is pretty new, and is used with the new G2 models and V4/A4.
JCM and Deformers do practically the same Job,  they deform the body in a natural way when you bend, twist or rotate a bodypart. Using magnets deformers has an advantage that you can  translate them in the clothing, (magnetise clothing) so that the clothing follows the body contours when you pose the model, and you don't have to made special morphs in the clothing.
Unfortunately V4 still has some JCM morphs, so you still have to add these morphs in the conforming clothing.
Bopper.
IsaoShi ( ) posted Tue, 23 September 2008 at 4:37 PM
Thanks, bopper, but to be honest I'm fed up with hearing different versions / corrections of what JCM actually stands for.  No doubt you are right, but what the hell, it does the same thing.
:O)
bopperthijs ( ) posted Tue, 23 September 2008 at 4:57 PM
Okay, sorry don't want to be a wise-crack. You're right: it does the same thing... Let's keep it by that. 🆒
Bopper.
drew555 ( ) posted Wed, 24 September 2008 at 5:11 PM
OooOOOoooooo that's what "magnetise clothing" means........
Handy, handy - nice one.
A reinstall fixes all - Ancient proverb.
