Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 19 10:45 am)
Hi, I just got PMDedit from the store here and from what I am reading it looks like it is really easy to make INJ_REM files with this tool. It has a short PDF that explains how it works, but it seems very simple and straight forward. You might check it out, it will make the rem files for you.
Mike
Quote - Hi, I just got PMDedit from the store here and from what I am reading it looks like it is really easy to make INJ_REM files with this tool. It has a short PDF that explains how it works, but it seems very simple and straight forward. You might check it out, it will make the rem files for you.
Mike
Mike,
I just spent close to $200 this month (September) in Poser stuff, that is close to 4 months normally for me. I cannot afford to spend another dime till the 15th of October.
Poserverse The New Home
for NYGUY's Freebies
Quote - Can you not ..................... ? :blink:
A picture is worth .............................. what you paid for it, n'est pas? ....
cheers,
dr geep
That I knew about but I want to create a pose file that will remove morphs with out the end user having to do too much work.
I think there are some free apps that will do it but I don't remember what they are, Oh where is Acadia she's great at this. I bet Ockham or lesbently would know. (hope I spelled their names right.) There was a tute in a thread just a week or so ago on this I will look.
Attached Link: lesbentley post
lesbentley gave this help to me on how to make a REM pose for a non-INJ figure and it worked perfectly.Here is another lesbently tute: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2883862 This one uses morphmanager which is free.
Quote - Here is another lesbently tute: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2883862 This one uses morphmanager which is free.
Morph Manager won't work
Let me try to rephrase the question - Can I create a pose that will remove all morphs or is there a way to create a pose with a text editor to remove the morphs?
Sample of the pose file
injectPMDFileMorphs :Runtime:Libraries:Pose:V4 AFCO:A4 Top Morphs.pmd
createFullBodyMorph FBMA4AikoPetite
createFullBodyMorph FBMA4Realistic
createFullBodyMorph FBMA4Stylized
createFullBodyMorph FBMA4AikoBody
actor BODY:3
channels
valueParm FBMA4AikoPetite
name A4 Petite
valueParm FBMA4Realistic
name A4 Realistic
valueParm FBMA4Stylized
name A4 Stylized
valueParm FBMA4AikoBody
name Aiko4
Here is a step by step tutorial for creating inj and rem files that you can watch on You Tube, it explains what you need to write into the Cr2 ect.
http://www.youtube.com/watch?v=7Yw_dNk1-IQ Perhaps it will help.
Quote - Here is a step by step tutorial for creating inj and rem files that you can watch on You Tube, it explains what you need to write into the Cr2 ect.
Mike what I am trying to do is create a pose file to remove the morphs not a cr2 file
a very simple REM pose:
Version
Number 4
readScript ":Runtime:Libraries:!DAZ:Blackhearted GND4:MORPHNAME_03-lShin.pz2"
readScript ":Runtime:Libraries:!DAZ:Blackhearted GND4:MORPHNAME_03-rShin.pz2"
and the remMORPHNAME_03-lShin.pz2 script looks like this:
version
number 4
actor lShin:1
channels
targetGeom MORPHNAME
name -
indexes 0
numbDeltas 0
keys
static 0
k 0 0
Quote - a very simple REM pose:
Version
Number 4
}and the remMORPHNAME_03-lShin.pz2 script looks like this:
version
number 4
actor lShin:1
channels
name -
indexes 0
numbDeltas 0
keys
static 0
k 0 0
Thanks I will experiment on this tonight.
Quote - > Quote - Here is a step by step tutorial for creating inj and rem files that you can watch on You Tube, it explains what you need to write into the Cr2 ect.
Sorry I said CR2 I meant PZ2 the tute deals with INJ-REM files.
I think I have it figured out with help of Blackhearted.
Ya the tute was exactly the same thing. shows you how to do it by hand with a txt editor step by step.
How to create a generic remove morphs Pose?
I have a outfit I am working on and created some morphs for it for different figures, but the app I had used to create the morphs did not create a remover of the morphs. How hard would it be to do this?
Poserverse The New Home for NYGUY's Freebies
