Did you check "render only selected objects" in the render options?
Could you temporarily delete the other objects just to render the alpha of the object you want?
(as long as you don't need shadow silhouettes of the other objects on your desired object).
Sorry I can't test this now as I have a scene open I'm working on.....
Hmm.... glad that worked but...
Looks like Multi-pass is really your best ticket. It allows you to select from among all the objects which ones you want in the alpha. And it supports occlusion shadows as well. Saves as multi-layer psd with alpha. I guess you need PS or else need to render separate files? A bit of a hassle at first but it seems pretty clear and flexible.
Remember the Fifth Element? "Multi-pass, multi-pass..."
Yeah only multi pass works
and her'es another PIA thing:
if you turn on G buffer, and render so an alpha of a chosen object appears on screen...you CANNOT save it, unless you select a save to multipass in the render dialogues, even though the damned image of the alpha's there on screen, you aren't allowed to save it, gah!!
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
Bruno,
bah, only advancement change I don't like ;)
"I'd rather be a
D&D items, stories.
You can save by clicking on render window, but...unless g bufffer and alpha AND save to a file on disc is selected beforehand, you sitll can't save the rendered alpha on screen!
jeesh.
So, youc an save an alpha of ALL elements rendered at any time,
but, to save an alpha of a specific thing you have GOT to have g buffer and save to a file done, before you render.
man that's a PIA!
"I'd rather be a
D&D items, stories.
In previous versions of Vue, if you had an object selected, and you rendered, that object would be used as an alpha, but not with V6I, this has bugged me for ages
It just makes an alpha of EVERY object, grrr. So you have got to make a Multipass G-Buffer render to get alphas.
scratches head, puzzled
Probably just me not seeing something obvious, again ;)
