Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
What method are you using to load the separate groups in Poser?
You could test to see if it’s possible to bring any of the morph groups into Poser as an obj. import. This will determine if the objs. are acceptable in any form. Sometimes Poser decides it doesn't like a particular obj. for some reason.
If the morph objs. will not load as objs. try exporting them from Zbrush again, and if that doesn't work, load and save the objs in some other modeler program if possible.
Thanks for your reply!
When you go to export the object from Poser, I check off both the morph target option and the groups options. Then I import it using a ZBrush plug in called "Poser Scaler." I then morph it to my liking, export using the same plug in and then I try to load it onto the "chest" group. I've also tried applying it to "Body" as well. When I try to add them, the Poser screen acts like it's locking up and won't do anything. I've even tried importing just the "body" instead of all of the groups (it's only a scalp cap thing) and it still locks up. I've tried importing the objects and they seem to load. I'm just not sure why it would lock up on a simple scalp cap by trying to apply it as a morph.
I'll have to try your other suggestions soon -- thanks!
--R.
Hi all,
I'm running Poser 7 and 'm trying to create a morph in ZBrush to use on some conforming hair. I follow all the necessary steps, I export all parts of it, enable "as Morph target" and to export it's groups. It loads fine in ZBrush, so after I finish creating the morph, I go into Poser to and try to load it, but when I do it locks up. Does anyone know why this would happen and how to fix this problem?
Thanks!
--R.
