Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 4:13 pm)
i run the full adobe suite, level CS2. So far I have not had to use Premier; I do everything I need in After Effects.
AE should be able to open your clips, you can put them on the timeline, apply filters and transitions, insert text/titles, then output the entire thing.
Now, I output to apple's H.264 but AE can output to other codex.
How much post-processing do you have to do, over and above just stringing the clips together?
::::: Opera :::::
I heard very good opinion about Jahshaka.
I tried to make some clips with this editor but interface knock me down. Anyway it is freeware, probably powerful tool.
http://jahshaka.org/
Good luck
I use Premiere, and it does everything you want.
For a cheaper alternative, you could try Editstudio. I think there is a version of Editstudio that is free. The latest version costs $89. I used EditStudio professionally for many years, doing work for TV, so it is well capable.
Your specialist military, sci-fi, historical and real world site.
aaargh! don't render these things as AVI's!
Never ever, not even with zero compression.
Compression makes compositing a bear, because you'll never get a clean edge or alpha, and recompressing the composite will produce lots of artifacts.
When rendering Poser animations, save as numbered TIFs . . . Poser will save out a perfect alpha with each one.
Will make your life way easier.
On the PC, I use Discreet Combustion (an old version, which works just fine). Jahshaka seems very similar.
(BTW: love your "Corman's Comeback" image)
I generated about a dozen AVI clips at 1600 x 1050. Does anyone know a good program (free or otherwise) that will let me combine/edit them and output at the same resolution? Movie Maker 2 seems to only output at 640 X 480. I read horror stories about Pinnacle Studio, but nothing official yet on Adobe Premiere CS4 for professional level editors. Anyone using CS3 ? I'm running Vista 32.
