Tue, Dec 24, 11:23 AM CST
Subject: V2 eyebrow chaos!!!
itzamna ( ) posted Wed, 27 June 2001 at 1:36 PM ยท edited Fri, 09 August 2024 at 2:30 PM
Okay. First off I want to thank JKeller for the helpful info. That definitely got me a little further from where I'm at. I'm still a little stuck with the eyebrows though. I'll attempt to attach a picture of what my problem is here and maybe someone out there can tell me what I need to do to get them looking a bit better. Sorry about the crappy picture but I'm a newbie! :)
JKeller ( ) posted Wed, 27 June 2001 at 1:48 PM
It looks to me like you haven't assigned a transmap to the material. In the Material Editor, select the UpperEyebrows, assign a transmap, and then set the transparency min and transparency max both to 100%. Hope this helps.
nplus ( ) posted Wed, 27 June 2001 at 2:20 PM
just to add alittle to what jkeller said...only add the transmap to the UPPER EYEBROW...the one labeled EYEBROW uses the head texture. I personally like to remove the eyeborws from the head texture so as not to interfere with the upperbrow trans map. You'll get it.
melanie ( ) posted Wed, 27 June 2001 at 8:45 PM
Transparency only to the upper eyebrow. If you put transparency to the base eyebrow, you'll end up with black holes in the the head. Melanie
