Fri, Nov 22, 6:50 AM CST
Subject: Rendering in Wireframe mode..??
ClintH ( ) posted Tue, 21 September 1999 at 7:26 PM · edited Fri, 22 November 2024 at 12:55 AM
Ok, I was doing this a few months ago without any problems. But havent been able to remember how the heck I did it. I want to render a figure in Wireframe. I thought I had to do it through the Make Movie option and chose Use Current Display Settings. I have the display in Wireframe mode. I go to make move set that up and all it will let me do is an AVI. Makes sense to me but I thought thats how I was doing it a while back. Help...I blew that brain cell somewhere along the way. Yikes. Any help is greatly appreciated as always. Thanks, Clint Ps - Poser 4.
Clint Hawkins
(Zakk Wylde (2007))
Xurge ( ) posted Tue, 21 September 1999 at 8:24 PM
All you do is display the wire frame view, Then File-Export-Image. Done. Pose On!!!!!!!! Xurge
Upir ( ) posted Wed, 22 September 1999 at 1:12 AM
The Make Movie method is the one I use. When I bring up the make movie dialog the drop box that lets you chose what type of file I have the option of making an "AVI" or "Image Files" I just select "Image Files", get all the other settings fixed up the way I want them and hit "OK" or whatever it is. Then it brings up the dialog where I can chose what file type I want to save as, JPEG, TIFF, etc, and where I want to save it. I'm working with Poser 4 also, so if that option isn't available to you, I have no clue as to why. Upir--strange things are afoot at the Circle K
ClintH ( ) posted Wed, 22 September 1999 at 7:27 AM
Ok - Hey, Check it out. 3 ways to do it! Upir, Xurge and mad-bios, Thanks so much for taking the time to reply. Have a great day! Regards, Clint - Ray Dreamers Forum
Clint Hawkins
(Zakk Wylde (2007))
Floydd ( ) posted Wed, 22 September 1999 at 9:29 AM
4th way: Someone (coldrake?) posted an image here in the last couple of days where they used the default UV template as a Transparency Map - resulting in a wireframed render.
Spike ( ) posted Wed, 22 September 1999 at 10:42 AM
I posted one a few day ago. http://www.poserforum.com/messages.ez?ForumID=12356&Form.ShowMessage=32525 Spike
You can't call it work if you love it... Zen Tambour
Floydd ( ) posted Wed, 22 September 1999 at 10:50 AM
Thats the one! Sorry Spike - brain fog.
Spike ( ) posted Wed, 22 September 1999 at 11:04 AM
No prob. Spike
Floydd ( ) posted Wed, 22 September 1999 at 11:47 PM
Spike - btw, I gave your method a shot and liked the results but my wireframed image rendered out with nasty jaggies. I guessed that this was because the map was just too small. For your piece, did you use the Poser default template from the CD and soften the edges with the transparency controls, or did you create a larger, hirez map template? -floydd
Spike ( ) posted Thu, 23 September 1999 at 10:37 AM
I think I used a 1500X1500 or maybe it was 2000X2000 Spike
Floydd ( ) posted Thu, 23 September 1999 at 7:57 PM
Thanks!
