Gotem. Loveem. Can't get them to work. Sorry. I'm still a newbie with poser. How do you get new texture maps to work on clothing? Your help would be great!
http://schuetzenpowder.com/sigs.jpg
zorares, for 'Stringwhite', load up the Biker Shorts then in the Surface Materials menu set the object colour to white and the highlight colour to black. Apply 'Ministring_TEX.jpg' as a texture map and 'Ministring_TRS.jpg' as a transparency map, with Transparency Min and Transparency Max both set to 100%. The end result will look odd in preview mode, but it'll look right once you render the image. I haven't downloaded the black panties yet, but the same method should apply, it's a time-honoured technique for creating posette lingerie. Hope this helps. gps
![file_185115.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_185115.jpg)
These are so stunning!!!! I can't thank you enough for your work and gererosity!! Available in Freestuff
