Mon, Nov 25, 4:47 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Subject: problems matching bump and color maps.
cyberknight1133 ( ) posted Mon, 27 October 2008 at 11:08 PM · edited Mon, 22 July 2024 at 1:17 AM
Is anybody else having problems lining up bit and bump maps in Vue 6 inf.? The problem is especially obvious with brick and boards. Changed from object standard to parametric doesn't seem to help. I've also noticed that my old Vue 5 inf. files that have poser imports (changed to VOB) render with mismatched maps.
Rutra ( ) posted Tue, 28 October 2008 at 1:36 AM
I never had such problems. Maybe some more details and screenshots would help us pinpoint the problem?
garyandcatherine ( ) posted Tue, 28 October 2008 at 10:19 AM
give us a screen shot so we can diagnose the issue
cyberknight1133 ( ) posted Tue, 28 October 2008 at 8:45 PM · edited Tue, 28 October 2008 at 8:47 PM
Inside the white border is an example of the mismatch between bitmap and color map. The surrounding image is the same thing with the two maps correctly lining up. What is really odd is that the settings are pretty much the same. All I did was change from object parametric to object standard, change the interpolation method a few times in vain, changed it back and it worked.
cyberknight1133 ( ) posted Tue, 28 October 2008 at 8:46 PM
Here are the settings I used...
Rutra ( ) posted Tue, 28 October 2008 at 9:31 PM
This is just the settings for the color map. What about the bump map? Did you attach a different bitmap to the bump node or did you attach the grayscale version of the color map?
But I noticed now you wrote now it's working?
