Tue, Jan 7, 11:10 PM CST
Subject: V2 Eyebrows continued
itzamna ( ) posted Wed, 27 June 2001 at 10:27 PM ยท edited Tue, 07 January 2025 at 11:06 PM
Okay things seem to be coming along here thanks to all your help. I really appreciate it. :) There's one problem I just can't seem to figure out and that's with what appears to be like a shadow of the other eyebrows appearing over the texture map ones. I've tweaked a bunch of settings but can't seem to get rid of that. Is there any possible way to remove the original eyebrow settings from the model when I start before actually applying the texture mapped ones? This is another picture of what's going on so far. Thanks.
AlleyKatArt ( ) posted Wed, 27 June 2001 at 10:46 PM
Hmm... if you want to get rid of the larger eyebrows, scroll down through the morph targets and find a morph called 'BrowGone' I believe. Or 'Brow Remove' one. I don't know exactly. But that should fix the whole problem.
Kreations By Khrys
JKeller ( ) posted Wed, 27 June 2001 at 10:51 PM
Looks like you are almost there...it's a little hard to tell but it looks like the problem you are having is due to one of two things. First, make sure the highlight color of the UpperEyebrows is set to true black (Hue: 160, Sat: 0, Lum: 0, Red: 0, Blue: 0 Green: 0). Second, make sure that the Eyebrows (not EyeBrows) has an Object Color and Highlight color that match the up with the Object Color and Highlight color of your SkinHead material. Hope this helps.
aheinz ( ) posted Thu, 28 June 2001 at 7:55 AM
Could also be the bump map if you are using one - can't tell from here. But have a look on it. Over the eyebrows of some bumpmaps is an area of unifom gray. Do some painting there or clone from the areas around it - this solves the problem usualy. Bye, Arthur
itzamna ( ) posted Thu, 28 June 2001 at 9:15 AM
Okay guys, thanks a bunch for all your help! I finally figured the eyebrows out with the info you gave me. You guys are good. Real good! I couldn't have figured it out without all of your helpful input. Thanks again! This image is what I came up with so far. The eyebrows definitely look so much better!
