Tue, Feb 18, 10:30 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
Subject: V4 elite Seams on render help requested.
Dynamo ( ) posted Sat, 01 November 2008 at 9:04 AM · edited Fri, 31 January 2025 at 1:42 PM
I know this was discussed a while ago, but using the search i cannot find the solution for this.  It appears on all skins, is there a fix?
Mariny ( ) posted Sat, 01 November 2008 at 9:16 AM
 What render settings do you use??
Dynamo ( ) posted Sat, 01 November 2008 at 9:22 AM
please see the attached...
gibby.g ( ) posted Sat, 01 November 2008 at 10:01 AM
I had a problem a while back in which seams apparently showed it turned out to be an artifact from lighting. I stopped using the default lights and usually use spots as my main lights. This helped alot.
Dynamo ( ) posted Sat, 01 November 2008 at 10:18 AM
thanks!
Kuladen ( ) posted Sat, 01 November 2008 at 11:15 AM
There is also a python script from SVDL that turns off texture filtering, and this corrects the problem of the seams on the Elite textures.
