TerraTerrains can go in your bitmap folder. I put the TGHarvest folder in Materials...
LVS - Where Learning is Fun!
I just use the Bitmaps folder since this is the first place Vue will look for any graphic type of stuff (terrain brushes, jpg, tif, bmp, etc.).
I organize my files a bit differently. This is because I use Vue on both a laptop and desktop computer and I want all my files available to me on both devices. So I set up a folder "C:Vue" which contains a bunch of 'my' folders and looks like this:
C:Vue
--- MyAtmospheres
--- MyBitmaps
--- MyDocs
--- MyFilters
--- MyFunctions
--- MyMaterials
--- MyObjects
--- MyPlants
--- MyScenes
Anything which does not come preinstalled with Vue, goes into a folder in these folders. I typically have folders within folders as well. For instance in my 'MyAtmospheres' folder I have the following folders each with different atmosphere presets:
C:VueMyAtmospheres
--- Bad Weather
--- Chipp
--- Cornucopia
--- Lush Atmospheres
--- Monsoon Atmospheres
--- Overcast sampler
--- SkinVue2
--- TerraAtmospheres
--- thomasKrahn
This way, I only need to synchronize one folder between the two computers: C:Vue
FWIW, I use Allway Sync on Win XP to manage the synchronization. I also use Allway Sync to backup my C:Vue folder to an external hard disk-- and I explicitly set it to NOT PROPOGATE DELETED FILES. This way, just in case for some unexpected reason my sync gets out of control and deletes some/all files between the 2 computers-- I still have a backup.
That said, I've never had a problem with Allway Sync deleting files.
HTH,
Chipp
Hmm,
That is interesting so I could move the annoying 'my documents' folder into Vue.
Matter of interest do you need 2 licenses to use on a desk top and laptop and what is your laptops spec?
I'm just about to purchase based on the tread and the info on site.
I will give you my feedback when I get time to play....
Quote - andrewe_665-seaview? is that another package, if it is where do I get it?
TerraTerrains can be installed anywhere as they are not 'linked' to any of the files. You use the terrains in the Terrain Editor to create different terrains. You should have a folder called "Bitmaps" next to the others (Materials, Scenes, etc.). If not, just create one there called "Bitmaps" and put TerraTerrains inside.
Yes.
