Sun, Jan 5, 8:10 AM CST
Subject: V4 Skin Realism Kit - Poser Pro?
tastiger ( ) posted Sun, 13 July 2008 at 3:51 PM · edited Fri, 03 January 2025 at 10:14 AM
Can someone tell me if FaceOff's V4 Skin Realism Kit available at Daz needs updating to work with Poser Pro or not?.....
Also - are there any other Python scripts that will need downloading again for use in Poser Pro apart from Occlusion Master and Unimesh Realism Kit?
TIA
The supreme irony of life is that hardly anyone gets out of it alive.
Robert A. Heinlein
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz   3.50 GHz
64.0 GB (63.9 GB usable)
Geforce RTX 3060 12 GB
Windows 11 Pro
nruddock ( ) posted Sun, 13 July 2008 at 4:28 PM
Quote - Can someone tell me if FaceOff's V4 Skin Realism Kit available at Daz needs updating to work with Poser Pro or not ?
It should do as the dialogs look to be using Poser's own GUI toolkit stuff.
Quote - Also - are there any other Python scripts that will need downloading again for use in Poser Pro apart from Occlusion Master and Unimesh Realism Kit?
If the script has a GUI, run it, if it works your golden, if it fails, post the details (script name, author and exception message) so someone can suggest appropriate further action.
Tashar59 ( ) posted Sun, 13 July 2008 at 5:06 PM
Yes, it works for me. In fact, I using it right now on a render. LOL.
face_off ( ) posted Mon, 14 July 2008 at 4:09 AM
Pls see http://www.physicalc-software.com/forum/viewtopic.php?t=137
Looks like Poser standard SR3 incorporates the python column change that Poser Pro did - so all P7 SR3 users will need to download the latest versions of my scripts.
Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
cherokee69 ( ) posted Mon, 10 November 2008 at 2:52 PM
Paul,
Is there going to be a script for M4 now that he is out?
Thanks
face_off ( ) posted Mon, 10 November 2008 at 9:09 PM
At a guess - I'd say the V4 kit will work with M4 (less the Gens).  Perhaps someone could confirm this?
Blog
Facebook
Tashar59 ( ) posted Mon, 10 November 2008 at 10:15 PM · edited Mon, 10 November 2008 at 10:17 PM
Yes, I used it on M4 with my first M4 test render. It tells you that it is not V4 but will apply if you want it to. Works fine. You could just copy/paste for the gens.
This is the test render. edit to say the texure was the low rez, so you can see how well it works.
