Tue, Nov 26, 9:05 PM CST
Subject: Make bodysuit for M4 or any figure using base mesh poser and a text editor.
albertdelfosse ( ) posted Thu, 13 November 2008 at 3:51 AM · edited Sat, 23 November 2024 at 4:26 AM
Want to have a body suit for M4 free? This will show you how to do it.
1.  Find michael 4.cr2 in your poser runtime directory, and load it into your text editor.
2.  Find and remove everything between the { and } brackets for these lines below. For example:
   actor head:1
       storageOffset 0 0 0
       geomHandlerGeom 13 head
   actor head:1
actor head:1
    storageOffset 0 0 0
actor eyeBrow:1
    storageOffset 0 0 0
    geomHandlerGeom 13 eyeBrow
actor rEye:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rEye
actor lEye:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lEye
actor upperJaw:1
    storageOffset 0 0 0
    geomHandlerGeom 13 upperJaw
actor lowerJaw:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lowerJaw
actor tongueBase:1
    storageOffset 0 0 0
    geomHandlerGeom 13 tongueBase
actor tongue01:1
    storageOffset 0 0 0
    geomHandlerGeom 13 tongue01
actor tongue02:1
    storageOffset 0 0 0
    geomHandlerGeom 13 tongue02
actor tongue03:1
    storageOffset 0 0 0
    geomHandlerGeom 13 tongue03
actor tongue04:1
    storageOffset 0 0 0
    geomHandlerGeom 13 tongue04
actor tongue05:1
    storageOffset 0 0 0
    geomHandlerGeom 13 tongue05
actor tongueTip:1
    storageOffset 0 0 0
    geomHandlerGeom 13 tongueTip
tor rHand:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rHand
actor rThumb1:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rThumb1
actor rThumb2:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rThumb2
actor rThumb3:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rThumb3
actor rIndex1:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rIndex1
actor rIndex2:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rIndex2
actor rIndex3:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rIndex3
actor rMid1:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rMid1
actor rMid2:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rMid2
actor rMid3:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rMid3
actor rRing1:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rRing1
actor rRing2:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rRing2
actor rRing3:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rRing3
actor rPinky1:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rPinky1
actor rPinky2:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rPinky2
actor rPinky3:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rPinky3
actor lHand:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lHand
actor lThumb1:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lThumb1
actor lThumb2:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lThumb2
actor lThumb3:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lThumb3
actor lIndex1:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lIndex1
actor lIndex2:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lIndex2
actor lIndex3:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lIndex3
actor lMid1:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lMid1
actor lMid2:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lMid2
actor lMid3:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lMid3
actor lRing1:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lRing1
actor lRing2:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lRing2
actor lRing3:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lRing3
actor lPinky1:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lPinky1
actor lPinky2:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lPinky2
actor lPinky3:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lPinky3
actor rFoot:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rFoot
actor rToe:1
    storageOffset 0 0 0
    geomHandlerGeom 13 rToe
actor lFoot:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lFoot
actor lToe:1
    storageOffset 0 0 0
    geomHandlerGeom 13 lToe
3.  Save file as bodysuitm4.cr2.
4.  Next go into the following directory RuntimePythonposerscriptsGeomMods  and  open
     bulgefigsnormal.py.
5.  Change  the line rndMagnitude = 0.01 to rndMagnitude = .002.
6.  Save the changed file.
7.  This is the script if you do not have it with your version of poser.
Bulge out all the vertices in all the figures based on the polygon normals...
import random
scene     = poser.Scene()
figs = scene.Figures()
for fig in figs:
    actors = fig.Actors()
    for actor in actors:
        try:
            geom     = actor.Geometry()
        except:
            # do nothing
            pass
        else:
            if(not geom):
                continue
            verts     = geom.Vertices()
            norms     = geom.Normals()
            i = 0
            for vert in verts:
                rndMagnitude = 0.002
                vert.SetX( vert.X() + rndMagnitudenorms[i].X() )
                vert.SetY( vert.Y() + rndMagnitude
norms[i].Y() )
                vert.SetZ( vert.Z() + rndMagnitude*norms[i].Z() )
                i = i + 1
            # So it gets written out with changes if user saves the poser file...
            actor.MarkGeomChanged()
scene.DrawAll()
8.   Open poser, and load in bodysuitm4.
  1.   Go into the material room and select 4_innermouth.
  2. Delete the color texture node.
  3. Set specular color to black (0,0,0).
  4. Set the diffuse color to a green blue (64,128,128).
  5. With posersurface node selected
           A. Right click.
           B. Select apply to all.
           C. Click ok.
  6. Exit the material room, and go back into the pose room.
  7. Now do the following:
           A. Click on file.
           B. Click on run python script.
           C. Browse to the following file RuntimePythonposerscriptsGeomMods and open
               bulgefigsnormal.py.
          D. Select it in the popup window, and click on open. This will expand the mesh a bit.
  8. Save your bodysuit as bodysuitm4 in poser figures section.
  9. Load in michael 4, and he should be covered by the bodysuit.
  10. Comform the bodysuit to michael 4, and there you go. You should turn ik's off, and zero
           everything out on both figures before conforming.  After conforming the bodysuit to michael
           4,  zero out the bodysuit again. For some reason the conforming process f**ks up the
          alignment of the bodysuit. Once this is done your all set.
The changing of the cr2 code, is to get rid of the head, eyes, tongue, hands, fingers, feet,and
toes. The python script expands the mesh outward by the amount set in rndMagnitude. Why
you can't use scale, xscale, yscale, zscale along with xtran, ytran, and ztran to do the same
thing as the python script is beyond me. I tried, and could not get it to work. Going into the materal room, is to get rid of any default figure textures.
With this method, you can apply all of m4's morphs to the just created bodysuit, and textures
as well. Using the above as a guide, you can make bodysuits for any poser character.
Here is a pic of m4 with his new bodysuit.
GKDantas ( ) posted Thu, 13 November 2008 at 4:36 AM
Just to remember that you can do that in any character but CANT distribute the file... hope they create a bodysuit soon to him.
Follow me at euQfiz Digital
Lucifer_The_Dark ( ) posted Thu, 13 November 2008 at 4:54 AM
Silly question, do you have to leave the "actor" lines in or can they be deleted too?
ps thanks for this :D
Windows 7 64Bit
Poser Pro 2010 SR1
albertdelfosse ( ) posted Thu, 13 November 2008 at 10:23 AM
Not sure on the actor lines. I'd keep them in.
By the way I forgot to add a couple of lines of code to change in the cr2 above.
actor neck:1
storageOffset 0 0 0
geomHandlerGeom 13 neck
actor neck:1
As to giving away the bodysuit for free. You can. What you have to do is:
  1. Put the bodysuit, and the obj files for it in a zip file.
  2. Encode the zip file (creating a rte file) using rtencoder (a free program) and the m4 base.
  3. Anyone who has purchased the m4 base file, and has the free rtencoder progam, can then
        decode the rte file back into the original zip file.
  4. Unzip the zip file into posers runtime dir.
LostinSpaceman ( ) posted Thu, 13 November 2008 at 2:20 PM
Attached Link: http://www.renderosity.com/mod/bcs/index.php?ViewProduct=64988&Start=1&vendor=Dimension3D
There's an inexpensive program that does this already for you in the marketplace made by Dimension3D called 2ndSkin. I highly reccommend it! I've had it for a while now and he has updated it many times since I bought it.
