Tue, Nov 12, 9:08 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Carrara Free Stuff here.
Subject: Physics falling through?
chuckerii ( ) posted Fri, 21 November 2008 at 1:13 PM · edited Tue, 12 November 2024 at 9:07 PM
I'm having trouble with physics... when I drop an object, it bounces on the plane below a few times then falls right through the plane.  Any one else having this problem and any ideas how to fix this?
Chuck
TOXE ( ) posted Fri, 21 November 2008 at 5:00 PM
Hi Chuck,
it depends on the object. If it's a infinite plane it don't work right at all. Try to edit your object in the vertex room and triangulate it. Usually it works fine.
-TOXE
chuckerii ( ) posted Fri, 21 November 2008 at 10:47 PM
Quote - Try setting the accuracy/geometry settings higher(Edit->Edit Scene Effects->Physics tab). Objects at higher velocities/bouncing will also punch through objects alot at default settings(or explode/fly away effect). 😄
Thank you!  In all my years of Carrara use I had never messed with these settings before or even knew they were there.  Increasing Simulation and Geometrics did the trick.
Chuck
