Mon, Jan 13, 4:06 AM CST
Subject: Vue 6 Pro Studio problem with Vista?
thartwick1 ( ) posted Wed, 26 November 2008 at 6:52 PM · edited Mon, 13 January 2025 at 3:16 AM
Just got a new Quad core machine running 64 bit vista. Vue 6 has crashed a couple of times and now I just ntoced when I go to Render Options and select Render to Disk and then try to browse for a folder, it doesn't open a window for me to select a file type/file location. I have Vue 5 installed and that works fine. I don't get it. Any help or ideas would be appreciated.
thartwick1 ( ) posted Wed, 26 November 2008 at 7:02 PM
Well, I found it. The file path didn't exist. Okay, on to the puzzle. I upgraded to Pros Studio 6.60 and when the first time I executed after the update, it crashed and burned and I had to re-install.
Peggy_Walters ( ) posted Wed, 26 November 2008 at 8:02 PM
Right-click the exe icon and select run as adminastrator...
LVS - Where Learning is Fun!
thartwick1 ( ) posted Wed, 26 November 2008 at 9:33 PM
Quote - Right-click the exe icon and select run as adminastrator...
Thanks, will give that a go!
thefixer ( ) posted Thu, 27 November 2008 at 1:31 AM
Always a good idea to switch the UAC off too, that can cause problems.
Injustice will be avenged.
Cofiwch Dryweryn.
thartwick1 ( ) posted Thu, 27 November 2008 at 5:02 AM
Quote - Always a good idea to switch the UAC off too, that can cause problems.
Thanks!  Appreciate the hints!
