Mon, Nov 25, 10:30 PM CST
Subject: Thought this wouldn't happend to V4.2
UrbanChilli ( ) posted Sat, 15 November 2008 at 10:24 AM · edited Mon, 25 November 2024 at 8:46 PM
What do I do to get rid of this wierd bend?
richardson ( ) posted Sat, 15 November 2008 at 11:41 AM
Set side to side to zero on forearm. You can fudge and offset side to side till crease improves too. Only for the still shot though..
If you use P7 there is the morph brush.  And always the joint editor...
UrbanChilli ( ) posted Sat, 29 November 2008 at 10:31 AM
I'm using P6 and the side to side did work a bit but not enough. I need her arm in that possition.
kuroyume0161 ( ) posted Sat, 29 November 2008 at 12:52 PM
If there are no morphs/'morph magnets' to cover this, then using a magnet or JP bulge settings are two possible solutions.  Unfortuantely, Poser's rigging/skinning isn't sophisticated enough to act like muscle deformers or do collisions to avoid interpenetration of polygons.
 -- Bjarne Stroustrup
Connatic ( ) posted Sun, 30 November 2008 at 9:38 AM
Or you could easily fix it in PSP or PS with a deformer brush.
UrbanChilli ( ) posted Sun, 30 November 2008 at 11:12 AM
It's fixed now, thank you all. I've decided to pose her a bit different after all.
Yes I know it can't be fixed in post, but I was puzzeld because I thought this wouldn't happend on V4
