Vue F.A.Q (Last Updated: 2024 Oct 17 8:34 am)
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3329811
There was a thread some days ago about memory usage in V7, see link. The memory usage in V7 is higher than in V6, apparently, but I never noticed something as radical as what you are experiencing. Maybe there's some specific item that's causing it. You could delete one by one to see if there's a "jump" in some of them.Also - check your settings - Undo Levels for example.
When I installed Vue 7i as an upgrade, it set my Undo Levels back to 5, while I had it set to 2 in Vue 6i.
That's all very well, it's still very worrying that a system running with 8 Gigs of RAM can drop to 52% of that memory in direct comparison to Vue6.
Whichever way you cut it or check this and check that, in the final analysis it still shouldn't be dropping that much IMO!!
Vue 6 didn't, I don't see why 7 should!
I have to say I'm very disappointed that there seems to be a memory issue yet again, lessons from Vue 6 appear not to have been learned!
Injustice will be avenged.
Cofiwch Dryweryn.
I don't think you should take conclusions that fast. Agiel is perfectly right. The undo levels wastes a big amount of memory. You probably had Vue6 with 1 or 2 (I know I did) and if you didn't change it in Vue7, it has 5. If you want to compare vue 6 and 7, you have to make sure that the starting conditions are the same.
I believe I am comparing apples to apples. I checked my undo levels, for example, and they are both at 5. When I open Vue 6 I after a reboot without doing anything but having the blank scene open, my resorces are 85%. When I reboot and do the same with Vue 7 I, the resources are 74%. I have tried this numerous times with the same results.
I also find V7 using more memory that V6, but as Chipp points out, I've had V7 down to 12% resources and no crash, whereas V6 used to crash on me anywhere under 45%.
And, as he says, there are significant new resources using memory - resources I'm very happy to have and use.
Have also loaded big .obj models into V7 that crash V6, with no problems - except some slowing of the GUI.
Ok, some checks, opened Vue6 and Vue7 from start up, blank default state, both showing 89% free resource, so that's good!!
Undo levels in Vue7 were indeed at 5, but so are my Vue6 ones when I checked, so like for like there too!
The scene I was using didn't use any of the new fetaures as far as I know except for any differences in the display management!
It's not my intention to run the app down, I love Vue, but I really think this will show to be an issue as more peeps start using it, admittedly I haven't pushed it to a crash yet, it's still worrying that with 8 Gigs I drop to 52% resource, at this rate I'll need 16 for Vue8!! [LOL].
Cofiwch Dryweryn.
Vue 6 Infinite scene, resources free showing at 76% which is kind of usual for what I do, lots of Poser imports!
Same scene in Vue 7 Infinite, resources down at 56%, the lowest I've ever seen Vue drop on my system which has 8 Gig of RAM.
Anyone else noticed the resource drop??
There's something not right there I think!
Cofiwch Dryweryn.
