I do like thefixer, only one runtime, and everything runs fine. I used to have several but I kept having problems with imports. However, I've read of people with multiple runtimes and have no problems. Why some have and others don't... I have no idea. I don't think much about these things, as long as it works, it's fine for me. :-)
If you mean the .pzz or .pz3 file when you say "Poser file", I think I may know why Vue asks you to locate the textures.
I have looked at many of my poser files (created in Poser 6 & 7) in a text editor, and inside all of them, each texture is listed according to the exact path in which it was located when I first created the scene. This obviously includes the drive letter, etc.
So when I transferred my runtimes to a different drive later on, the scene files themselves still had information inside them pointing to the old location of the textures.
To avoid this hassle, I handled it 1 of 2 ways:
(If you don't like editing your scenes in text editors), you can also:
How do you do this in Poser? Go to the menu, choose --
Scripts, Utility, collectSceneInventory, Copy all to folder
Vue will first look for the textures in their original locations, and when it doesn't find them, it will 'spot' them in their new location (because they are in the same directory as your .vue scene). So Vue will show this message:
"Unable to find file (then it gives the file's original path) --
Use file (mentions the file it found in the copied location) instead?"
Choose "yes to all", and Vue will then automatically use all the other texture files in that same folder.
I prefer method # 1 btw. : )
And I sincerely hope this helps. ; )
**EDIT: **I need to add that I had to decompress my .pzz files in order to edit them. The .pzz files look like gibberish inside text editors, but the .pz3 files have language I can read! :p
I recently got a new computer (which I'm pleased with). But I've got 1 problem. I reinstalled Poser Pro and Vue on my new computer, and I copied my runtime from my old Poser install to my new computer. I then went in and added the runtime to the list in Poser. But when I try to import a Poser file into Vue, if any of the scene I bring in is in the old Runtime, it can't find the textures, and it's a pain to have to guide it to it everytime. BTW, it finds the stuff in the main runtime just fine. Any suggestions as to how I can fix this?
