Carrara F.A.Q (Last Updated: 2025 Jan 15 2:29 am)
Wow! Nobody ever had an answer for this? So much for me looking for the answer via the search engine! I've been doing the same thing in C5Pro tonight. Fiddling with a sky to get it how I want it and clicking the little floppy icon on the atmosphere to save it to my library as a cbr file and selecting atmosphere but when I go to reload it there's no sky thumbnail and it doesn't load.
I have some purchased skies that I would like to have thumbnails for in the browser. Anyone know how to manually do that?
Klebnor
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device. Beige horizontal case. I don't display my unit.
There maybe some confusion. Both cbr and car files can be saved w/ thumbs, Just save a car file ,which is a scene file as a preset. Perfect for a sky.
Easiest place is to save them as a car file, w/ comments and a preview under the my presets directory under my documentss/daz /carrara. (on windows) Then just go to your scene tab if you need to to make sure that folder is added to the browser. Think it is by default, but not sure if there is a my scenes folder. I think I made this to go under that my docs, then added it to the browser so I can put scene presets there. It's not hard just a bit manual.
Previews have to be saved w/ that option checked for the file.
Keep in mind that the C browser is particular about what file goes on what tab. The misc tab is a bit more flexible. But you can add a folder or update the info. If a folder is added and you see it listed in the treeside, but nothing is showing on the view side of the browser you have the file in the wrong category.
No need to think outside the box....
Just make it
invisible.
I've just spent a bunch of time tweaking a sky in Carrara, and I wanted to save it as a preset like I can in Bryce, but it doesn't look to be possible. I thought it might save under scene effects in the browser, but I can't find a way to do it. Is there a way to add it to the list of presets? Any suggestions? -Jeff
