Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
...there's both more AND less going on here than meets the eye. There are no actual flower models. What you see is a bit of smoke and mirrors created with a couple of terrains, and a nifty bit of textures I created in Photopaint. 1. I went out into the yard and grabbed a few pansy blossoms. 2. I Scanned them into the computer. 3. I Created several different colored Photopaint Image Sprayers. 4. Using a layered technique in Photopaint I painted hundreds of pansy blossoms in both color and alpha map form. 5. In Vue4, I created a terrain and spent a lot of time molding it, (it's the toughest part) and applied a foliage type material to it. 6. I duplicated the terrain and raised it slightly above the 1st terrain. 7. On the 2nd terrain, I created a material using the pansy color map and the pansy alpha map. (for the transparency) 8. Last, but very important, I took the 2nd terrain back into the terrain editor and added pebbles to the surface. This keeps the flowers from looking too flat. There you have it. Simple, no? -SMT
Ummm...okay, I almost got it. It's basically the same method at the "distant forest" but using an image map for the flower portions, yes? Is all the green "grass" we can see in this image part of terrain #1, or just some of it? It really does look very cool, and I like Mark's idea about applying it for autumn images, too. :)
You've got the hang of it. It is similar to the "Distant forest. The grass in the background is simply the default grass material applied to the infinite ground plane. I used a more primitive version of this (mapping on a ground plane) when I wanted cherry blossoms covering the ground below a cherry tree. you should be able to use it for any kind of semi-flat ground cover. -SMT
How very aromatic! :D In the Vue 3 manual (English), check page 204. If you can't find your manual, take a look in the objects browser under the Samples category, and you'll find a "Distant Forest" sample terrain already built. In the manual, it explains how to build it, which is similar to how Steve built his pansies. :)
