Mon, Feb 17, 1:22 PM CST
Renderosity Forums / MarketPlace Showcase
Welcome to the MarketPlace Showcase Forum
Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Feb 16 8:12 am)
Welcome to the MarketPlace Showcase Forum. The Showcase Forum and Gallery are intended for all commercial related postings by active Renderosity MarketPlace Vendors only. This is a highlight area where our membership is invited to review in greater detail the various art products, software and resource site subscriptions available for purchase in the Renderosity MarketPlace.
Subject: 200+ Action Poses! ActionStorm now available!
shadownet ( ) posted Mon, 10 November 2008 at 11:07 AM · edited Thu, 30 January 2025 at 2:45 PM
Attached Link: ActionStorm
The pose set is for V4 - customized to work well with the Stormchaser Outfit for GND4.   You can find more on the Stormchaser outfit [here](http://www.renderosity.com/mod/bcs/index.php?ViewProduct=67510).  Also an expansion set for the clothing [here](http://www.renderosity.com/mod/bcs/index.php?ViewProduct=67538).
shadownet ( ) posted Mon, 10 November 2008 at 11:11 AM · edited Mon, 10 November 2008 at 11:20 AM
Some samples of the [ poses](http://www.renderosity.com/mod/gallery/index.php?image_id=1775050).
Beta44x ( ) posted Tue, 30 December 2008 at 3:15 PM
does it work for v3 too?
shadownet ( ) posted Tue, 30 December 2008 at 3:48 PM
While I often use poses made for one figure on other figures, I do not recommend it unless you do not mind tweaking your pose a bit after you apply it.  Because of the difference in how V4 and V3 joints and body parts are set up, the V4 will not apply the same to V3.  It will get you close, but you would have to do some manual adjusting of the V3 figure after applying the pose in most cases.  Usually this is only a very small amount of adjusting but some poses will require more and some will require little or none.  A lot will depend on how closely the rotation of body parts affected in the two figures match each other.  One simple trick that helps between the two figures is to lock the feet and toes on V3, and apply the V4 pose, and then unlock and manually pose the V3 feet/toes as needed - if needed.  Fingers can also sometimes cause problems.  Most everything else will work fairly well.  V3 has a buttocks group and V4 does not but both have thigh groups so the legs generally pose fairly close.  The collar groups differ in set up too but do not seem to cause too much problems when sharing poses.   Mostly I find it is the feet and fingers.
Please let me know if you have any other questions.  I am always glad to try to answer if I can.
Rob
