Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 6:38 pm)
Quote - Auto_Fit is already ticked and the problem still exist and I can not locate the texture maximum size or where to locate it.
If you don't have a maximum texture size in the preview Render Settings, it just means that you're using P7.
Does the background image render correctly in a still ?
What Renderer / RenderSettings are you using ?
Is the picture your using the same size / aspect ratio as the final render ?
Firstly, I want to take time to thank you for having the patience to answer my question. Now to reply your questions: You are right. I am using P7
I look forward to your reply. Thank you
As stills render correctly with your background image, then it sounds like this could be a Poser bug.
Are you rendering your animation to seperate images or are you rendering the whole thing direct to an AVI file ?
If your doing the latter, you should try rendering to seperate images and assembling them afterwards.
Obviously if you're already doing that, then it maybe that there's a subtle difference between your render settings for stills and those you're using for the animation.
Please, I need some help. I made a six second animation with an imported background picture. But after rendering the animation the background picture does not fill the whole of the background and hence, the animation does not look real. I have attached a sample of that animation to help make my question clearer.
Does anyone have any ideas of how I can create more realistic animation?
