Thu, Jan 9, 12:32 PM CST
Subject: Proublem wiht Sreed
smalll ( ) posted Sun, 04 January 2009 at 9:20 PM · edited Thu, 09 January 2025 at 12:27 PM
Hi
I have a question.
You know, Sreed.
When I view in Sreed, there appered strange line.
Can I fix it?
hborre ( ) posted Sun, 04 January 2009 at 10:41 PM
Does the preview look normal in OpenGL?  If it does and you are not having problems rendering, then leave your settings in OpenGL.
smalll ( ) posted Sun, 04 January 2009 at 11:07 PM
Hi, hborre.
Nice to meet you again.
Yes. It looked normal in OpenGL.
The line appeared in Sreed render only.
Can I fix it?
hborre ( ) posted Sun, 04 January 2009 at 11:30 PM
It is a driver issue with the video card.  Usually the recommendation is to switch to the other setting to solve the problem.  Again, if you can render in OpenGL without problems, then keep the settings on OpenGL.  No need to switch to Sreed.
smalll ( ) posted Sun, 04 January 2009 at 11:47 PM
Thanks to Mr. hborre.
You give me great help.
Daymond42 ( ) posted Mon, 05 January 2009 at 12:02 AM
I had the same issue on my ATI Rage, and now that I moved to a GeForce card, it no longer has that issue.
It was certainly odd, though, because it did not give that issue with every model, and of course it rendered just fine, so I didn't really mind much, but it was nice when I found that OpenGL fixed it.
Currently using Poser Pro 2012 (Display Units = feet)
AMD Phenom II 3.2ghz (6 cores)
8gb RAM
Windows 10 Pro 64bit
smalll ( ) posted Mon, 05 January 2009 at 4:11 AM · edited Mon, 05 January 2009 at 4:12 AM
Thanks to **Daymond42
**I see.
