Wed, Nov 13, 11:16 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: unconform poser with out it moving
bigdave1960 ( ) posted Thu, 08 January 2009 at 8:08 AM · edited Mon, 11 November 2024 at 12:14 PM
I know this might sound a bit odd I want to know if you can unconform a hair style in poser .I have a scean set up and ive changed my mind about the hair  i chose and wish to use another one . problem is when i conform the one i want to use its a bit too high it needs to be adjusted  yTran, but i cant do that whilst its conformed and if conform to none it moves it miles away form the model and the position and angle of head means I cant get it into the right  place .if it would conform to none and stay were it is a quick tweak of the y Trans dial would be a perfect fit .
ockham ( ) posted Thu, 08 January 2009 at 8:27 AM
Attached Link: Unhide parameters
Conforming hair is a headache for sure.  If you can't adjust the Ytran of the Body, there's usually one body part that *can* be adjusted directly.  Maybe the Head?
And if the Ytran for the Head is hidden, this little script will unhide all the parameters.
After adjusting, you can probably re-save the hair under a new name so you won't
have to do it again.........
My python page
My ShareCG freebies
bigdave1960 ( ) posted Thu, 08 January 2009 at 9:02 AM
Thanks that did the trick
