Sun, Jan 19, 1:37 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 19 10:45 am)
Subject: Victoria in Poser?
stankygrrl ( ) posted Thu, 08 January 2009 at 10:48 PM · edited Sun, 19 January 2025 at 10:56 AM
Hi,
Sorry, but I'm new.
I installed Victoria but I can't find her in Poser. It seems to have installed it in my DAZ folder. She comes up fine in DAZ Studio, but I can't find her in Poser.
What am I doing wrong?
Thx :-*
Winterclaw ( ) posted Thu, 08 January 2009 at 11:18 PM
Try reinstalling her, but when you do there's a drop down box that will give you a list of things to install to, select poser.  If you are using poser 7, then select poser 6.
Once you install her for poser, if you are using Vicki4 you'll then need to initialize her.  There should be an icon on your desktop to do that.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
stankygrrl ( ) posted Thu, 08 January 2009 at 11:25 PM
Wow. Initialize? I never had to initialize other stuff I downloaded. I'm generally scared to do things I don't understand on this machine. It's expensive.
What does the initialize do?
Thanx :-*
IsaoShi ( ) posted Fri, 09 January 2009 at 3:36 AM
The initialise script is to do with setting up V4.2's injectable morphs, which work in a different way to previous V4 versions. That's the non-technical explanation - there is more about this in her documentation.
You need to run the script after installing V4 itself, and again after installing any add-on morph products such as V4 Morphs++ or V4 Muscle Morphs.
pakled ( ) posted Fri, 09 January 2009 at 10:13 PM
Try under Figures, then Daz People. At least that's where she shows up in Poser 5...
bopperthijs ( ) posted Sat, 10 January 2009 at 1:55 PM
I think that when you installed her you choosed the daz-studio option instead of the poser-one, when was asked which program you use. in that case you have to reinstall her and choose poser as targetprogram. ( you don't have to un-install her if you want to use her for daz-studio as well. The initializemacro are only neccessary when you have installed the ++morphs.
Good luck
Bopper.
