Sat, Jan 25, 10:46 PM CST
Subject: question on transferring morph?
vxg139 ( ) posted Sun, 11 January 2009 at 2:33 PM · edited Sun, 12 January 2025 at 2:18 AM
Hi,
Would you guys know of an an easy way of transferring body morph between two A3 figures? (such as pFootSock)?
Thanks for your help
Cheers
vxg139
jonnybode ( ) posted Sun, 11 January 2009 at 2:58 PM
Hi!
Look for the free program morphmanager, it will do the job.
Otherwise you can export the preferd bodypart as an *.obj (morphtarget selected in popup window), and import it again to the new charater.
Regards / Jonny
hborre ( ) posted Sun, 11 January 2009 at 6:09 PM
Online Now!
If the morph is created by spinning the property dial, just select the body part, copy and then paste on the same selected body part of your similar second model.  All done within Poser.
vxg139 ( ) posted Sun, 11 January 2009 at 6:13 PM
Thanks for the heads up guys....I did try jonnybode's suggestion (morphmanager) and it worked like a treat....
Will try your approach too hborre.... your apporach seems to be much faster!!
Thanks again guys....
Cheers
vxg139
