Do not use Ultra.
Ultra has "advanced effects settings" of 77%, if I remember correctly. One of the things that this settings controls is the quality of procedural terrains (it also controls other stuff, such as volumetric light, etc). You do not need 77% for a normal procedural terrain. This increases render time with no visible gain in most cases.
In fact, do not use any preset render setting. All the settings, from Final to Ultra, are, in my opinion, really poorly balanced. For example, Ultra, although it has such high "advanced effects quality", it has a too low anti-aliasing (80%, if I remember correctly). That's too low for many plants and clouds.
Always use user-settings render settings and adjust to the type of scene you have at hand. Each case is a case. In your particular case, try with advanced effects settings at, say, 40%, and compare. There could be other settings to adjust to get a good render time with procedural terrains, but this is the first that comes to mind.
Another thing: in Vue 7, the processing of procedural terrains is much faster... That's a good reason to upgrade. :-)
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3357632&ebot_calc_page#message_3357632
This was discussed already several times in this forum. See the link for one of these threads. In this post I link, I also link Peggy's document for render settings and my own additional recommendations.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Only twice have I tried to render a scene using procedural terrains and both times it took so long it just didnt seem worth it. I constructed a new procedural terrain tonight to experiment with and started rendering it with Ultra, came back about an hour later to check the status and saw that 0% had rendered and it was estimated that it would take 1360 hours to render. My comnputer is only a year old, I have almost 4 gigs of ram and a quad core....I'm just wondering if this is normal and if so if there's any way around it.
