Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Do you have a screenshot, so we can see where the lights are pointing?
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
Everything is set for raytracing, everything is set to cast shadows, and
in fact I get a shadow.
If you've got everything set for shadows, I can think of two possibilities:
either your point lights are not really inside the cave, or perhaps the
cave has its normals pointing outward, or is two-sided?
My python page
My ShareCG freebies
Point lights only do ray-traced shadows.
You did not mention - did you enable ray-tracing? That is necessary.
Attached Link: http://www.renderosity.com/mod/gallery/index.php?image_id=1703403
I've done an image a while back using those caves also and I had problems with the shadows also. Getting the model on the actual cave floor and placing a light closer to the figure and pointing at it solved my problems and gave me the result wanted.
Food for thought.....
Dan,
You said "point lights". There are no shadow cams for point lights. They only do ray-traced shadows. You didn't answer my question. I asked you if you enabled ray tracing. You won't get any ray-traced shadows without ray-tracing and you won't get any shadows on point lights without ray-traced shadows.
And also you do not need to "point" a point light at anybody. A point light will shine in all directions. It always makes a shadow in every direction.
Free men do not ask permission to bear
arms!!
arms!!
You got shadows now, but you figure is still floating in the air :-)
The black splotches are a common artifact of Poser ray-tracing. They show up with reflections, refractions, ambient occlusion, and ray-traced shadows. In every case, increasing ray bias (not decreasing as first suggested) makes them go away.
The trade-off is that if you increase the ray bias a lot, ray-tracing will ignore certain things that you don't want it to ignore.
I don't know the actual mathematical reason this happens. There's nothing in the manual about the details of Poser's ray-tracing algorithms. I just know that there is a fundamental flaw in Poser's ray-tracing that requires a ray bias to avoid it. A ray bias tells the renderer to ignore certain geometry for purposes of seeing what the ray is intersecting. It has something to do with concave surfaces creating spurious self-shadowing. It is particularly visible when you have surfaces that are concave (pardon the pun) due to displacement. It happens somewhat less when the actual geometry is concave, but it still happens.
I really like the last picture. Even if the splotches are artifacts, they look
realistic on cave walls. Often real caves are covered with white bat guano,
"mummified" bat carcasses, and limestone deposits.
My python page
My ShareCG freebies
an easy solution for the artifact issue is to not have the cave cast shadows. and i've had items i had to turn off shadows for because i won't go above a certain shadow bias. but it looks like you don't really need light from outside the cave, right? i mean, if you were doing a silhouette at the entrance of a cave image, then you'd need it to cast shadows so the cave could be darker. but i can't see an opening here.
oh, and you'll lose shadows from cave features. forgot about that. you might not want that.
I am trying to figure out how to make this a prop so my camera access panels will show up and then I can try and figure out how to open them up to make the inside visible from the outside. Having to keep the camera in the cave limits the shots available somewhat.
arms!!
*Often real caves are covered with white bat guano,
*OCKHAM - R you a SPELUNKER???
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
http://www.renderosity.com/homepage.php?page=3&userid=580115
Quote - **Ok I have taken the cave into Deep Paint 3D and painted out the floor seam. Then I dipped it into UV Mapper Pro and welded the crack in the ceiling. Now I am back on the lighting. Here the min shadow bias is cranked to ten on each of two lights inside the main cavern area.
I THINK you can make this see-through by making sure you're not using double walls. If you've got a single.sided model with the normals facing inwards, you ought to be able to look into it from the outside And therefore place a camera on the outside and still have it render what's in the cave.
I like that cave a lot btw. Wonderfully creepy!
When you look at the back of a polygon in preview it is invisible, but I don't think it is invisible in render. Many times I've accidentally put my camera outside a room, thought I was in it, and when I rendered all I get is the wall and can't see inside.
If you are not doing ray-tracing reflections from inside the cave, there is a workaround. Use the render option to remove backfacing polygons. This is not the same as seeing through a polygon. For the purpose of that render it is completely removed. Very handy.
But if you happen to be using a shiny reflective surface in the cave, the polygons facing away from the camera (and towards the interior objecs) will be missing.
![](https://live.cdn.renderosity.com/forum/threads/2761260/file_422115.jpg)
**I have modeled a cave and have placed two point lights in it. I have enabled shadows in the properties for both lights. I have also enabled shadow casting in the render properties. Should I not be seeing some kind of shadow being cast by James as he runs through my cave? I am using Poser 6.**Free men do not ask permission to bear arms!!
