Wed, Jan 1, 4:15 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 01 3:25 am)
Subject: Playing With 3D Format Conversions (Poser-anchored)
infinity10 ( ) posted Sat, 24 January 2009 at 8:06 AM · edited Wed, 01 January 2025 at 3:52 AM
... or pointless long holiday weekend activity ... or got a 3D itch which needs to be scratched
Downloaded free human figure models from SP Effects.
http://www.speffects.com/
Decided to use the male figure.
Discovered it is in FBX format and Maya format.
But I do not have Maya, and I want to use the figure inside Poser Pro.
I looked for FBX format convertor.
Found the Autodesk FBX Convertor tool (free, stand-alone)
http://usa.autodesk.com/adsk/servlet/index?id=6837478&siteID=123112
I downloaded the windows version and installed it.
Converted the FBX human male figure into 3DS, OBJ, and DAE (collada) versions.
Tested by importing the 3DS, OBJ, and DAE versions into Poser Pro directly.
Figure gets corrupted in each case.
Unable to use the first-generation file conversions directly inside Poser Pro.
Exited Poser Pro.
Launched Google SketchUp 7.
Imported the DAE conversion of the human male figure.
Exported as KMZ.
Unzipped the KMZ file with folder structure intact, using 7zip ( I am certain that Izarc, Winzip and Stuffit would all do the unzipping fine as well).  This step produced the second-generation DAE version of the human male figure.
Launched MeshLab.
Imported the second-generation DAE file.
Exported as OBJ.
This is the second-generation OBJ format of the human male figure.
Launch Poser Pro again.
Imported the second-generation OBJ version.
Success.  No mesh corruption.
However, the imported item needs to be rotated -90 degrees along x-axis, and then raised along the z-axis until the feet touch ground.
Inside Figure Setup Room, attempted quick-n-dirty rigging using Poser figures.
James Rig - failed
Don Rig - failed
Poser 4 hi-res male Rig - failed
Poser 1 male Rig - passable success.
Materials Room adjustment required, but UVmapping seems to have carried forward throughout the conversions.
Note:  Eyeballs fallen down around left foot of figure.
Figure is poseable to a degree.
Best used as garden sculpture in 3D scene !!
Thus endeth the Playing with 3D Format Conversions.
Eternal Hobbyist
infinity10 ( ) posted Sat, 24 January 2009 at 8:07 AM
and here's the FireFly render of poseable garden sculpture
Eternal Hobbyist
befanini ( ) posted Sat, 24 January 2009 at 8:28 AM
Garden Gnome lmao
See your deviantart journal ;)
infinity10 ( ) posted Sat, 24 January 2009 at 9:06 AM
Metro-nome ???
Eternal Hobbyist
befanini ( ) posted Sat, 24 January 2009 at 9:12 AM
Metro-nome garden gnome to accent your home
You're so silly. XD
He totally could grace my courtyard, btw...
infinity10 ( ) posted Sat, 24 January 2009 at 9:29 AM
 He's poseable, so how he may disgrace your courtyard, is - heh heh - entirely up to you !
I think I need to change his fallen eyeballs to transparent.
Eternal Hobbyist
befanini ( ) posted Sat, 24 January 2009 at 9:35 AM
As he is. Aerodynamic is very good.
You can change them to transparent, but in my garden they stay as they are.
I'm quite liking the guy now! Hee hee :b_grin:
jdcooke ( ) posted Sat, 24 January 2009 at 2:58 PM
file_422444.txt
Great find,  Here are 7 of Rudy's UV templates, in PNG image format incase you want to try your hand at creating textures.
( just change extension from "txt" to "zip" )
good luck
jdc
infinity10 ( ) posted Sat, 24 January 2009 at 11:37 PM
 Thanks !!  That's great.  I could not get the IFF files which came with the original Rudy package, to work for me.
Eternal Hobbyist
