Thu, Nov 14, 10:12 AM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Fog comparisons in Vue
silverblade33 ( ) posted Sun, 25 January 2009 at 6:53 AM · edited Wed, 13 November 2024 at 9:27 PM
from previous thread :)
messign aorund wiht making Fog in vue, and also, smoke
#1 this fog made by WAY upping the amount of fog in amtosphere settings to 300% and higher
For real "fog" you have to shove it way up and render at high quality in the atmosphere settings or it's TERRIBLY "noisy".
silverblade33 ( ) posted Sun, 25 January 2009 at 6:55 AM
And now, the old classic, applying a material, in this case, a derivative of a metacloud material which is changed into a basic volumetric material
note you need ot do work so the edge of the sphere doens't show, such as using a huge sphere, or metablob and baking to polygons of a large number of spheres or rocks
silverblade33 ( ) posted Sun, 25 January 2009 at 6:57 AM · edited Sun, 25 January 2009 at 6:59 AM
And here using a metacloud, each sphere dropped to gorund, made same size, material tweaked for scale of the scene
IMHO, metalcouds make great smoke and non-standard fog :) But render times SUCK if you do not turn off INTERNAL SHADOWS and CAST SHADOWS in the material settings of the cloud material
even then it usually has hellish render times depdning on useage and scene.
alexcoppo ( ) posted Sun, 25 January 2009 at 9:08 AM
Here in northen Italy we sometimes have foggy scenes which would render quite fast in any program: anything beyond a few meters is just a solid white wall :lol:
I have sometimes seen in the evening situations in which the fog layers were just a few meters high, which a really sharp upper border. I think that in this case a simple cube, appropriately stretched with a cloud material would perfectly do.
Visiting the Terragen Planetside forum, I have seen references to photographs of meterological conditions so visually "unnatural" that, if rendered in any app, would make people say "...your clouds just suck... go back to learn the basics".
Bye!!!
GIMP 2.7.4, Inkscape 0.48, Genetica 3.6 Basic, FilterForge 3 Professional, Blender 2.61, SketchUp 8, PoserPro 2012, Vue 10 Infinite, World Machine 2.3, GeoControl 2
bigbearaaa ( ) posted Sun, 25 January 2009 at 8:21 PM
How does applying a fog or cloud material to a primitive work out?  It should be less overhead than a metacloud and you shouldn't end up with symetrical edges if you use a course bump map.
silverblade33 ( ) posted Mon, 26 January 2009 at 5:02 AM · edited Mon, 26 January 2009 at 5:02 AM
Quote - How does applying a fog or cloud material to a primitive work out?  It should be less overhead than a metacloud and you shouldn't end up with symetrical edges if you use a course bump map.
The 2nd image is fog material (variant of a metacloud mat, that changed ot a standard volumetric), on a very large sphere :)
and they don't have "bump maps" as they are volumetric, density etc. instead.
bigbearaaa ( ) posted Mon, 26 January 2009 at 7:26 AM · edited Mon, 26 January 2009 at 7:27 AM
Maybe I didn't explain myself clearly enough.  Here are two pictures of the results gained in about a minute (not including render time) by creating a cube primitive, elongating it, flattening it to the hight of the trees and then applying the thin white smoke material that comes with Vue.  I then increased density and quality until I was happy witht he effect.
bigbearaaa ( ) posted Mon, 26 January 2009 at 7:28 AM
Here's a more overhead view.  There are no hard edges and a bump map can be applied since it's an object not a cloud.
