It looks like you've lost the scrollbars that make it possible to expand the scale
both horizontally and vertically. If this is permanent (not just on one PZ3) you
might try a "partial reinstall". In other words, re-run the installer for the last
Service Release, which should overwrite most of the underlying DLL files.
My python page
My ShareCG freebies
Well, that's good.
"Messing around with layers" is a good hypothesis for the cause of the problem.
The whole Layers system is totally screwed, and I'm not at all surprised that it
screws up the other parts of the animation code!
My python page
My ShareCG freebies
"limited success and confusing results"
Yup, that's the same thing I got from the Layers!
My python page
My ShareCG freebies
AH Les and Ockham located in the same place at the same time -
hey guys do you have a good way to copy and paste animation curves in the animation graphs windows? I BELIEVE if you position and click your mouse and drag just right...Poser will function to highlight whatever portion of your curve and let you copy - but it is impossible to really get the work done exactly and efficiently , and also when you paste, it is pretty hard to get the paste to go down in the right spot, if the graph you are pasting to has any activity already in it..... If there was a way to copy the whole animation graph of one body part, and then paste this whole animation curve to a different body part's graph......... and better yet, also be able to paste the INVERSE curve, that would rock. Hmmmm, I wonder if I am asking for one of the functions that you might already be performing inside your JIGGLES, Ockham.
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
http://www.renderosity.com/homepage.php?page=3&userid=580115
Have a look at the image below
I've somehow messed up the scale, causing all the keyframes to squash down horizontally. This makes it tricky to select them
Any idea what I've done, and how to put it back to normal ?
