Fri, Jan 31, 6:47 AM CST
Forum Moderators: Staff
Subject: Is this possible in Poser - Movie projection using light
nyguy ( ) posted Mon, 02 February 2009 at 12:23 PM · edited Fri, 31 January 2025 at 6:43 AM
I am just wondering if using a spot light I could use it like a movie projector. If poser lights act like most real world lights It should be possible right?
Theory is this
  • have an open ended box with a spot light set to 300% intensity
  • have a plane with an image set at 50% transparency at the end of boc
  • have a plane about 50 poser settings away from the box
This should create A either a shadow on the plane or B an image that looks like a movie right?
Poserverse The New Home for NYGUY's Freebies
svdl ( ) posted Mon, 02 February 2009 at 12:38 PM
Might work. But you should definitely try translucency on the "film" at the end of the box.
My gallery   My freestuff
nyguy ( ) posted Mon, 02 February 2009 at 1:17 PM
Quote - Might work. But you should definitely try translucency on the "film" at the end of the box.
What I am going on that is using a gray scale image of the original file (see image here) as the transaprency. I figure a gray scale image would be better than just a B&W image.
dadt ( ) posted Thu, 05 February 2009 at 5:29 PM
Why not just use your image as a gel on the spotlight, either a still image or a movie file.
Miss Nancy ( ) posted Sun, 08 February 2009 at 11:56 PM
ny, ye'll be surprised at what happens when you apply an image map to the
diffuse channel of some lites in poser.  it's not really intuitive IMVHO.
