Fri, Jan 10, 10:55 PM CST
Subject: New Update Build 39290 is out
Mazak ( ) posted Tue, 03 February 2009 at 1:03 PM · edited Fri, 10 January 2025 at 7:47 PM
Vue 7 Infinite 7.21 - Build 39290 This update is still in beta. The following is a list of bug fixes and improvements included in this update:
  • Improved display when first keyframe isn't at zero time.
  • Fixed PNG module on MacOS.
  • Added missing QTVR file format on Windows.
  • Improved repartition of instances when using mixed ecosystem materials
  • Fixed hypervue single video file output.
  • Fixed file saving when path contain non-ascii characters (MacOS).
  • Fixed UI presets change on Windows.
  • Fixed crash after changing motion type.
  • Fixed range command line option for both StandAloneRenderer & RenderNode applications.
  • Improved export of polygonal objects with multiple textures.
  • Improved download of C3D Item.
  • Improved rendering of glow(external rendering and when using hybrid 2.5D effects).
  • Improved external rendering of hybrid 2.5D effects with multiple passes.
  • Improved Collada material import.
  • Fixed possible crash when loading back objects made of metablobs and/or boolean operations.
  • Improved C4D export.
Mazak
Google+ Bodo Nittel
thefixer ( ) posted Tue, 03 February 2009 at 2:13 PM
No fix for the Hulk then!!
Injustice will be avenged.
Cofiwch Dryweryn.
Mazak ( ) posted Tue, 03 February 2009 at 2:23 PM
Yes Vickys with Poser Shader looks like green tomatoes, but on my side I have SkinVue7 :biggrin:
Mazak
Google+ Bodo Nittel
thefixer ( ) posted Tue, 03 February 2009 at 2:28 PM
Lucky you!!
Cofiwch Dryweryn.
Darboshanski ( ) posted Tue, 03 February 2009 at 3:33 PM
Yes SkinVue 7 is a BIG help!
My Facebook Page
CobraEye ( ) posted Tue, 03 February 2009 at 5:24 PM
This problem is in vue 6!
I guess it will never be fixed now.
