I should probably mention it's for Vue 7 Infinite only......
The outer ring of surf turbulence in the illustration was done by just duplicating the terrain, expanding and lowering it a bit and then making it invisible. You often have outer rings of troubled waters because of underlying rock and reef structures.
M
Attached Link: Macro and Mat
I don't know if anyone's thrown any macros out there yet but here's one for you to play with.I call it SeaCliffsnFauxliage. No real plants in the material but it's great for distant or midgrounds or for an undercoat to your Solid Growth. The cliffs have wet at the bottom so you can just plop it into your ocean.
The sequence of steps in the terrain editor are as follows:
Regular terrain
512
Erode
Fluvial
Diffuse
Iceburg
Mountain
Diffuse
Trim around with splotchy brush
Clip
I hope you like it.
M
