Sun, Jan 12, 12:50 AM CST
Subject: switch material base on sun angle?
lightning2911 ( ) posted Fri, 06 February 2009 at 12:46 PM · edited Tue, 07 January 2025 at 7:27 PM
i would like the shadow part of a sphere have another material than the lit part ... can this be done in the function editor?
i am thinking i would need an angle of incidence but not from the camera to object but from sun to object.
any ideas how this can be done?
thanks in advance
chris
Cherryman ( ) posted Fri, 06 February 2009 at 2:15 PM
If you don't want to animate you can easy make a mixed or layered material.  Adjust the angle and height to get the distributian where you want it.
nruddock ( ) posted Fri, 06 February 2009 at 2:16 PM · edited Fri, 06 February 2009 at 2:20 PM
I suspect it can be done in Vue 7 (in editions that have full access to the function editor or with the appropriate module installed) due to the new ability to refer to the properties of other objects in a node network.
It may also be possible in Vue 6 an possibly 5 (same proviso) but you'd have to use a constant node instead of being able to refer directly to the Sun.
Cherryman ( ) posted Fri, 06 February 2009 at 2:20 PM
PS. I do not know myself how it fnctions, but maybe the "distance on ray" input node can help here also.
dburdick ( ) posted Fri, 06 February 2009 at 4:04 PM · edited Fri, 06 February 2009 at 4:09 PM
This is easily done in Vue 5, 6 ad 7 although it's a bit more automatic in Vue 7 because you can link the sun direction/orientation to the material automatically.  In Vue 5 and 6 you have to key in the sun rotation values.  Here's how.  Create a mixed material with the two materials you want to use.  Set up the distribution of the materials as follows in the function editor.  Basically, you are just doing a dot product of the sun's rotation against the normal (world standard) of the object.  In Vue 7, you can link the sun's orientation into the function editor automatically -- and when you move the sun around, it will automatically update the material distribution.  In Vue 5 and Vue 6, you have to manually key in the sun rotation coordinates when the sun is moved.
http://www.skinvue.net/Vue7/VueLightFresnel.jpg
lightning2911 ( ) posted Fri, 06 February 2009 at 11:39 PM
dot product ... of course :) you're my hero!
i love the function editor
