Mon, Jan 6, 5:55 PM CST
Subject: Question
Amanodel ( ) posted Sun, 08 February 2009 at 1:01 AM · edited Mon, 06 January 2025 at 5:52 PM
I work on an Asus Eee PC and it works wonderfully. Unfortunately I've filled my netbook's harddrive already. Largely in part due to my poser downloads. I'm going to be purchasing an external hard drive and was wondering if anyone knew if all of my data would transfer fine and how do I switch poser from drive C to the external drive?
IsaoShi ( ) posted Sun, 08 February 2009 at 3:58 AM · edited Sun, 08 February 2009 at 4:02 AM
Best practice would be to leave Poser itself installed on your internal drive and create an external Poser library (Runtime) on the external drive. All your content (current and future) will be on the external drive. (I think there are some people who do have Poser itself installed on a USB or Firewire drive, but I would not do this myself).
I have only ever used external libraries, but If I were doing this I think I would:
  1. Copy my Poser runtime onto the external drive
  2. Link Poser to it as an external library
  3. Go through the default Poser Runtime on the internal drive, deleting all my purchased content to free up disk space, making sure not to delete any Poser program folders.
  4. In the external Runtime, delete the Poser program folders, such as CG, Dots, LipSync, Plugins, poserHtml, prefs, ui, and Weblinks, leaving just the content folders.
By the way, I would also recommend getting a two-disk external drive with mirrored disks. It's a bit more money, but using an external disk gives you this option, and think of what you would lose if your single external drive failed... which they sometimes do!
EDIT: WAIT FOR MORE RESPONSES BEFORE DOING ANYTHING!! Others may have better ideas than mine. (It's actually more than likely!)
TrekkieGrrrl ( ) posted Sun, 08 February 2009 at 4:21 AM
 I'm running my Poser from an external harddisk. I't's only installed on my computer to help me get the file associations. Poser can theoretically run from anything. I've run it from a CD and a flash drive (USB stick)  just to prove a point :)
so just copy the whole Poser 7 (or whatever version) over to the new disk, make a shortcut to Poser.exe and that's it. :) Easy-peasy.
karibousboutique ( ) posted Sun, 08 February 2009 at 12:10 PM
You can have runtimes anywhere.  I have runtimes on three separate hard drives, with poser running on my main C drive.  And, yes, you probably can run Poser from any drive, too, though if it's not a serial drive, it will slow down considerably.  I suggest keeping Poser's main install on your C drive, and using external runtimes, just as IsaoShi suggests.  Just remember a few things:
  1. DAZ main figures (V4, M4, mil2dragon, etc.) don't like to be moved from your main runtime.  I suggest leaving them there, unless you go to the DAZ threads and read EXACTLY how to install them in other runtimes.
2) Python scripts must be installed in your main runtime.
  1. If you boot poser with your external drive unplugged, it will forget about your external runtimes, and you'll have to re-add them.
  2. Take IsaoShi's advice and get a redundant, self-backing drive. I lost ALL my runtimes about two months ago and had to start over.  NOT fun, I assure you.  Thankfully, I had backups of most of my install files on another drive.  In any event, back up EARLY and OFTEN.
Good luck!
Intel Core i7-8700 6-Core 3.2 GHz (4.6 GHz Turbo), 32GB RAM, two GeForce GTX 1080 Ti GPUs
DS 4.10, Photoshop CC and CS6, Poser 11 Pro, Vue 2016, CarraraPro 64bit, Autodesk Inventor, Mudbox, and 3DS Max
One in 68 children is diagnosed with autism.  One is mine.
