Fri, Nov 22, 12:37 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Integrate Tkinter and Snack with Poser?
MaterialForge ( ) posted Wed, 11 February 2009 at 1:05 PM · edited Fri, 26 July 2024 at 5:11 AM
I have a script I wrote that requires it (actually the script requires the Snack Toolkit, which requires Tkinter...), and not sure how to integrate this with Poser. Doesn't Poser 6 already have Tkinter installed by default?
What I want to do is build a GUI for the script which is currently command-line.
nruddock ( ) posted Wed, 11 February 2009 at 3:32 PM
Yes, P6 has Tkinter installed (PC only though).
The important thing is to match the versions of Python and Tcl/Tk correctly (2.2 and 8.3 for P6) for any precompiled binaries your trying to use.
This may or may not be sufficient, and if not you'll need to build from the source.
MaterialForge ( ) posted Wed, 11 February 2009 at 6:06 PM
Cool, thanks for the version number info. I did run into an issue, trying to use Python 3.0, and it won't recognize Tk. Looks like it's time for the manual build. I'll give that a shot.
