Hi gddesign,
They snuck a new one in whilst you were away. The latest patch is 4.03 available from www.cusiouslabs.com
I'm not 100% sure if that cures it but try that first.
Let the export dialog box open. Open another application (Workpad, Acdsee or whatever...) Click on Poser's export dialog box title bar (to get it in foreground) Now you can access all the options. You can let the other app in background. Actually, you can go to any other open window, then back to Poser and the function works. If no other window is already open, displaying the clock will work, also. Hope it helps.
Excuse me if this is an old topic - I've been away. Running Poser 4.02. Just moved from win 98 to win2K. Now when I export as a 3DS, I can't select the "export model as separate objects" box - it's there but not selectable. Worked fine under Win98. Haven't changed the Poser installation at all. Any known fix?
