Maybe the first message is the actual error. I've had that happen with a prop a couple of weeks ago.
You could check the texture map file with Photoshop/PSP/the Gimp., maybe resave it.
Quote - Right on the product page in big red letters:
**Poser 7 Users: Bonus Hairy version Not compatible with SR3.
Create another poser 7 install, and only update it to sr2... that'll do the trick!**
Thanks for the help! LOL, I was wondering what the SR3 was when I looked at the product the first time... I even did a web search with no luck. I've just installed Poser, I haven't updated anything as of yet so I guess I need to check the version that they have sent to me. Thanks again, sorry to bother with such an oversight on my part!
No biggie.. and sorry for that whole thing being in red.. evidently the text came over that way when I cut n pasted it.
I did the NightWolf PLUS set, so I knew the answer immeduiately, since I was dealing with it during developement.
Basically, the fur version was developed, and when the update was released to P7, if fixed a bug with old hair products, made new pones possible, BUT it also brokwe some things that depended on the bug existing.
Luthbel would have had to completely redo the furred version, and he already had many vendors counting on him for a specific release date, so he was kinda boxed in.
I know Luthbel is working on something else right now, and is way overdue on it.
I'm sure Smith Micro can get you a link for the original version.. send them a message about it, and why you need an old version. They are pretty good about things like that.
If you do get a solution to this, could you PM me here on Rendo? I have the same issue -- SR3 came with my version of P7. ( I just gave up on a hairy Lycan until Luthbel updated. But if you can get Smith to send you some sort of back-dated version, please let me know.)
I know lots of people who've followed the updates from day 1 just keep the old version of their installs, so that they have an original, SR1, SR2, and SR3 version on their machine. I sure wish I could do the same!
Intel Core i7-8700 6-Core 3.2 GHz (4.6 GHz Turbo), 32GB RAM, two GeForce GTX 1080 Ti GPUs
DS 4.10, Photoshop CC and CS6, Poser 11 Pro, Vue 2016, CarraraPro 64bit, Autodesk Inventor, Mudbox, and 3DS Max
One in 68 children is diagnosed with autism. One is mine. ♥
Just email Support at Smith Micro explaining why you need the older Service Release. They should be able to get it for you...
NOTE: You may need to roll back Video Drivers and other aspects of your System to allow Poser to run using only SR2... some of the changes were to address issues resulting from new Drivers and SP for the Operating System (I do not think SR2 will work on Leopard 10.5.6)
There is no Support for this, other than to install SR3
I am not sure why it will not work on SR3.. if someone can enlighten me, I would be most grateful.
ratscloset
aka John
Ratcloset: The hair room improvements cause the issue with the lyco hair product. Tiny is the most knowledgable person with the hair room that I know of, and she actually couldn't release proper hair products until P7 sr3 was released.
Luthbel was caught between a rock and a harfd place, and ended up just releasing his hair product for P7sr2 or less as a result.
My Nightwolf PLUS set also supports his fur CR2 as well, but again only works in P7 sr2 as a result.
I did see carrerra fur show as a wip by someone, but I don't think tjhat product ever materialized.
This won't be of any help I'm sure but here's my 2 cents.
None of my older furred creatures have stopped working with sr3 On the contrary, they all work better and dynamic hair is stable now. In my opinion this is not a Poser issue but rather how the hair is set up (as have been said earlier).
One thing I noticed with the Lycanthropos fur, when I had the chance to look at it, was the hair groups density was set much higher than I usually have on mine. Where I have 10.000 for density the Lyco' could have 200.000. I don't know if this happend with sr3 or not but it would have an impact on the render. Especially if one is using shadows and raytrace. Also the amount of strand vertices make a difference.
Thanks for that little bit of onfo on the hair groups, Tiny.
I just went through all the hair groups in the hair room and downsized the hair groups to density of 10 and verts to a maximum of 6, and now the hairy guy's rendering. This is in Poser Pro, which used to throw a fit and completely fail to render him before.
Cool :)
Hey guys. I'm trying to get this thing to work and it's just not happening. I even went so far as to uninstall Poser 7 and reinstall it up to SR2. Still not working.
Then I went in and modifed every body parts hair density to 10 and the vertices to 6 if it hey weren't lower.
Still not working.
Anyone else have any other advice?
Thanks.
Nope, tried that it didn't work. I've got a fairly fast machine. Duo core 3.0 processor, 3.5 gigs of ram and an Nvidia Geforce 7950GT vid card.
I"ve uninstalled Poser 7 and reinstalled it, only upgrading to SR2. I opened up the hairy Lycanthrope, changed all the body part to 10 density and less than 6 certs.
It still locks up when it tries to render. Well more to the point, it gives me the out of memory message.
I would REALLY like to use the hairy version of the critter, especially since I just picked up GOM's morphs for it (which made me want to get the lycanthropos in the first place).
If someone could maybe post some screen shots of what the hair room settings should look like, plus what settings you're using to render, that might help. I've been using Poser for quite some time now, although I will admit to not using the hair room all that often.
If anyone can help, it would be greatly appreciated.
Thanks!
Okay, I tried rendering it in a separate process. I lowered all of the hair settings by half. Made my render settings similar to yours.
This time, the shadows went through, but when it tried to render, it just stopped. I got no message claiming it was out of memory, I just got nothing. The box said rendering...it flashed blue all the way across then nothing.
I truly believe I'm cursed.
Attached Link: http://home.comcast.net/~forevernyt/pwpimages/wolfman.jpg
Well, I couldn't wait around to do it the easy way, so I settled for the hard way. Postworked the impression of fur and used Rawart's wolf texture.
OK I see..yes.. Even with the low settings and you having 3G mem...still it went all haywire..Thanks for the info Raven. I guess I just am unable to use the hairy guy then. Very difficult to render unless you have a high end system. I cant get more memory either because 2G is my systems max..Post work! LOL! Thanks Raven :)
Open the CR2 file in a decent text editor (I use EditPad, myself), then search-and-replace all instances of:
vertsPerHair 8
with
vertsPerHair 7
Save the file back into the library, and the fur should render properly in P8 now.
I cleaned up a few other things while poking around -- the hair and center-of-mass props have unnecessary morph channels, for instance, and I noticed redundant hairGrowthGroups that seem to serve no purpose -- but as far as I can tell, the vertsPerHair lines are the only real issue.
Thanks for the info...but it still not working for my. I get the error that I need to render in a separate process (what ever that means) or up my adaptation or lower bucket size. Then Poser crashes..:(
My 2G just is not enough memory I am afraid, but I am glad Raven is got it going on now! Thanks Little Dragon :)
I've looked high and low for a solution to this and I'm sorry if this isn't the forum for this (I'm new, do I get a break??) but I'm at a loss.
I've got a Daz3D Lycanthropos Night World figure I would love to get rendered but it freezes or just stops the render at the "rendering shadow map - light 1" then gives me the following error windows:
"Can't load texture. Bad File"
"Not enough memory to load the texture map."
"Texture could not be loaded. Image map file could not be found, or there is not enough memory to load."
Ok, this is a fresh install of Poser 7 and the Daz file is the only "extra" loaded. I've tried various setting in render with no luck. I've got a quad core with over 4gb of ram and a nvidia geforce 9800gtx+ card with the newest driver.....
any thoughts? ANY help would be great!
